path pilot on router
- Gotdiesel
02 Jul 2024 12:49 #304266
by Gotdiesel
path pilot on router was created by Gotdiesel
I have a home built router that I set up Path Pilot on. Well, I had an electronics guy set up that understood Linux. How do I set up new “home position” for reference and how to set up the new soft limits? I have limit switches, but Path Pilot only uses one limit switch per axis and assumes other end based on the machine you are using. Is there any way to have home and travel limits match my machine?
- Thank you received: 5337
02 Jul 2024 14:09 #304268
Replied by PCW on topic path pilot on router
Homing and machine limits are setup in the .ini file:
linuxcnc.org/docs/html/config/ini-homing.html
linuxcnc.org/docs/html/config/ini-config.html
(for machine limits see the "AXIS" section)
- gerritv
- Thank you received: 16
08 Jul 2024 19:30 - 08 Jul 2024 19:32 #304715
by gerritv
Replied by gerritv on topic path pilot on router
@gotdiesel, I replied on theTormach.com forum. A bit more Tormach/Pathpilot specifc although PWW's ref's will get you there as well.
forums.tormach.com/t/home-and-soft-limit...ith-pathpilot/1670/4
Last edit: 08 Jul 2024 19:32 by gerritv.
