Asus Motherboard + AMD5600gt
  • da_kernel@hotmail.com
  • New Member
  • New Member
09 Mar 2025 15:37 #323564 by da_kernel@hotmail.com
Asus Motherboard + AMD5600gt was created by da_kernel@hotmail.com
Hey guys, I'm trying to put my previous PC to use on my PCNC1100 S3 - pathpilot - 7i92t.  I get through the installation and it does freeze after I select my machine.  I have verified that the 7i92t does work as I borrowed another PC to test the 7i92t + PCNC1100 for functionality.  So I think it's some issue with my PC setup.
I get these errors during startup after the BIOS and before pathpilot:
Mother Board:  Asus a520M
CPU: AMD 5600gt
core perfctr but no constraints; unknown hardware
kobject: can not set name properly!
Any recommendations on bios settings or something to clear this?
thanks
  • Moderator
  • Moderator
13 Mar 2025 17:30 #323873 by tommylight
Replied by tommylight on topic Asus Motherboard + AMD5600gt
Download the ISO from the downloads page, burn to a USB, boot that PC from that USB, see if you can run any of the parallel port configs included.
All that can be done without installing just in Live mode.
Also try some sims.
There is no actionable info to help so far, so need more info, errors, smoke... :)
Time to create page: 0.058 seconds
