New Laser Build - raster engraving
- kramdradoow
09 Aug 2018 15:26 #115846
by kramdradoow
New Laser Build - raster engraving was created by kramdradoow
I have very recently retrofitted an old Huntron Prober into a laser engraver. I have reused the prober's hardware (steppers, timing belt drives and linear rails) and an old Xylotec board I had gathering dust. It didn't take much to control the 3 axis motion so that part is done. I bought a 5.6W 455nm laser diode with integrated ps regulation board. It came with a module to accept PWM input for control of the laser power levels.
It was pretty easy getting the laser controlled using M3/M5 and PWM output (Sxxxx) to turn it on/off at modulated power levels. Engraving vectors was pretty simple. I produced some simple engravings on wood and am pleased with that result. I then turned to raster engraving and ran into headaches.
I found that raster engraving is well outside of my comfort zone and technical experience (cnc router, mill, lathe). So far I have experimented with various photo editors (inkscape and gimp) along with some editing/postprocessing (ImageToGcode, 3dpBurner Image2Gcode, and a trial PicEngrave Pro6). The images that I have engraved all seem "overcooked". I then engraved some grayscale bars to see how my laser power control was functioning and observed some black bands at the beginning/end of each grayscale change.
It appears that physics comes into play.
Code to turn the laser on a a specific power level followed by a short move command (0.25") results in the laser firing and it "overcooks" until the machine can process the move instruction and accelerate to the proper feed rate. (just guessing here but this assumption seems reasonable to me) I can only imagine that for moves of 1 pixel in length it is not possible to do anything but burn too long. The machine cannot accel/decel anywhere near fast enough to prevent that burning.
I have looked at the graster solution (wiki.linuxcnc.org/cgi-bin/wiki.pl?Rastering_With_A_Laser) to synchronize the laser with the motion but I am using PWM output not a converted step/dir on an unused axis. Frankly, I don't think I'm capable of editing my HAL to successfully use that solution with my configuration. If anyone has any experience and advise to share with graster solution, I'd appreciate any help I can get.
I have read in this forum about speeds on parallel ports and MESA hardware which makes my head spin a bit. My PWM freq is 1KHz but can go up to 3KHz. (Measured with o'scope.) I can see the power levels vary with changes to the Sxxx param so I believe all of that is working properly. I used MESA hardware on my lathe and mill (LCNC) and Mach3 with Cxx/smooth stepper boards for my router. I realized that the Xylotec board is not the best choice of electronics but it was in handy and I had no idea how far I'd get so I chose the low buck route. I will likely use different electronics on my next laser machine (bigger work envelope and higher power diode) IF I can solve this raster engraving challenge.
I have not yet tried to implement M62 to synchronize the laser firing with the motion but am thinking that may be my next step.
Any help or comments would be appreciated. I can provide pics of the machine and output product. I can provide HAL and INI files if anyone is interested.
Mark
Mark
- Thank you received: 7488
11 Aug 2018 05:53 #115876
Replied by tommylight on topic New Laser Build - raster engraving
- Hakan
- Thank you received: 454
11 Aug 2018 07:22 #115877
by Hakan
Replied by Hakan on topic New Laser Build - raster engraving
I did some work on laser engraving (on another platform) a few years ago and recognize the issues you see.
The "overcooking" is most likely just too high intensity. Solved by lowering PWM (scaling the PWM) or traveling faster.
Black stripes when changing greyscale levels. The eye is very good at picking up and enhance such changes, but if it is more than that it is probably due to PWM reset. The PWM counter restarts the counter for the duty cycle with the ON part. That will create a subtle black bar that the eye picks up. The PWM has to change the duty cycle "on the flye" without a reset.
And then the most usual problem with this way of engraving. You want equal amount of laser energy at every pixel. Even at varying speeds. And there is nothing that compensates for the lower speed/longer time at the pixel/higher energy at acceleration. This is the real problem for everyone that tries to engrave using spindle speed as laser intensity. The only easy way to make this work, that I know about, is to make sure that the traveling speed is constant. So the engraving has to include acceleration parts where there is no engraving, All in one movement so there is no start/stop for any reason. It is probably doable. There are other solutions possible that includes making sure the intensity is at a certain level even at acceleration that includes timing the pulse length and stuff.
Either that, or have a look a graster. What I could see they have solved this.
- Hakan
11 Aug 2018 23:22 #115926
by Hakan
Here is an example of laser engraving (not with linuxcnc).
PWM reset is under control.
Laser pulse length is controlled to work also under acceleration.
The input is a run-length encoded image of the Lamborghini Gallardo.
It should not be impossible to do this in linuxcnc with some development.
16 Aug 2018 11:10 #116125
Replied by andypugh on topic New Laser Build - raster engraving
I think that LinuxCNC might pause motion momentarily on a spindle-speed change.
It might be worth trying M67 instead. That sends the new value at the same time as it sends the _next_ motion command.
linuxcnc.org/docs/2.7/html/gcode/m-code.html#mcode:m67
- kramdradoow
17 Aug 2018 11:28 #116198
by kramdradoow
Replied by kramdradoow on topic New Laser Build - raster engraving
Sorry to have gone silent on this but have had a series of family interruptions that are not yet over.
Last week after my initial post I did some preliminary work in my INI and HAL files to implement M62 and M63 to synchronize the laser firing with the next move. I modifed my post processor and generated some test gcode. All that done on my simulated system but I just have not had the time to test on the real laser engraver.
All worked as expected in simulation but....
Pete , My system uses PWM to control the laser power instead of analog which is why I didn't try M67. Am I thinking correctly or will M67 work with digital output also?
Mark
Mark
17 Aug 2018 11:35 #116199
Use M67 to set the duty-cycle of the PWM.
- kramdradoow
17 Aug 2018 11:44 #116200
by kramdradoow
Oops. Andy not Pete. I'll have to research how to do that. Thx for tip.
Mark0
Mark0
- raggielyle1@gmail.com
09 Feb 2026 08:33 #342700
by raggielyle1@gmail.com
Replied by raggielyle1@gmail.com on topic New Laser Build - raster engraving
Try this code
#!/bin/bash
# Laser Engraving Converter - Final Vertical Fix
echo "========================================"
echo " LASER ENGRAVING CONVERTER "
echo ""
# Get filename
read -p "Enter image name (without .png): " base_name
# Find the file
if [ -f "${base_name}.png" ]; then
png_file="${base_name}.png"
elif [ -f "${base_name}.PNG" ]; then
png_file="${base_name}.PNG"
elif [ -f "$base_name" ]; then
png_file="$base_name"
else
echo "ERROR: File '${base_name}' not found!"
read -p "Press Enter to exit..."
exit 1
fi
echo "Found: $png_file"
gcode_file="${base_name}laser.ngc"
echo "Output: $gcode_file"
echo ""
# Get settings
read -p "Enter target width in mm: " target_width_mm
read -p "Enter DPI [75]: " dpi_input
dpi=${dpi_input:-75}
read -p "Enter feed rate [500]: " feed_rate_input
feed_rate=${feed_rate_input:-500}
read -p "Enter safe Z height [10]: " safe_z_input
safe_z=${safe_z_input:-10}
read -p "Enter engrave Z height [0]: " engrave_z_input
engrave_z=${engrave_z_input:-0}
read -p "Enter minimum power [1]: " min_power_input
min_power=${min_power_input:-1}
read -p "Enter maximum power [500]: " max_power_input
max_power=${max_power_input:-500}
read -p "Cross-hatching? (y/n) [n]: " cross_hatch_input
cross_hatch=${cross_hatch_input:-n}
echo ""
echo "=== SETTINGS ==="
echo "Image: $png_file"
echo "Width: ${target_width_mm}mm"
echo "DPI: $dpi"
echo "Feed: ${feed_rate} mm/min"
echo "Safe Z: ${safe_z}mm"
echo "Engrave Z: ${engrave_z}mm"
echo "Power: ${min_power}-${max_power}"
echo "Cross-hatch: $cross_hatch"
echo ""
read -p "Continue? (y/n): " confirm
if ! "$confirm" =~ ^[Yy]$; then
echo "Cancelled."
exit 0
fi
echo "Converting..."
echo ""
cat > /tmp/laser_final_fix.py << 'PYTHON_EOF'
import sys
import os
from PIL import Image
def main():
if len(sys.argv) != 11:
print("ERROR: Wrong number of arguments")
return 1
# Parse arguments
input_file = sys.argv[1]
target_width_mm = float(sys.argv[2])
dpi = int(sys.argv[3])
feed_rate = int(sys.argv[4])
safe_z = float(sys.argv[5])
engrave_z = float(sys.argv[6])
min_power = int(sys.argv[7])
max_power = int(sys.argv[8])
cross_hatch = sys.argv[9]
output_file = sys.argv[10]
print(f"Converting: {os.path.basename(input_file)}")
print(f"Power range: {min_power}-{max_power}")
try:
# Load image
img = Image.open(input_file)
if img.mode != 'L':
img = img.convert('L')
orig_w, orig_h = img.size
# Calculate new size
pixels_per_mm = dpi / 25.4
target_px_w = int(target_width_mm * pixels_per_mm)
aspect_ratio = orig_h / orig_w
target_px_h = int(target_px_w * aspect_ratio)
actual_mm_w = target_px_w / pixels_per_mm
actual_mm_h = target_px_h / pixels_per_mm
mm_per_pixel = 25.4 / dpi
print(f"Image size: {target_px_w}x{target_px_h} pixels")
print(f"Physical size: {actual_mm_w:.1f}x{actual_mm_h:.1f} mm")
print(f"mm per pixel: {mm_per_pixel:.3f}")
# Resize
img = img.resize((target_px_w, target_px_h))
pixels = list(img.getdata())
# Generate G-code
with open(output_file, 'w') as f:
# Header
f.write('; Laser engraving - FINAL FIX\n')
f.write(f'; Image: {os.path.basename(input_file)}\n')
f.write(f'; Size: {actual_mm_w:.1f}x{actual_mm_h:.1f} mm\n')
f.write(f'; DPI: {dpi}\n')
f.write(f'; Feed: {feed_rate}\n')
f.write(f'; Power: {min_power}-{max_power}\n\n')
# Setup
f.write('G21\nG90\nG64\nG17\nG54\n\n')
# Initialize
f.write(f'F{feed_rate}\n')
f.write(f'G0 Z{safe_z:.1f}\n')
f.write('G0 X0 Y0\n')
f.write(f'G0 Z{engrave_z:.1f}\n')
f.write('M3\n\n')
# HORIZONTAL PASSES
f.write('; --- HORIZONTAL PASSES ---\n')
print("\nGenerating horizontal passes...")
for y in range(target_px_h):
# Flip Y: image row y (0=top) -> machine Y (target_px_h-1-y)*mm_per_pixel
y_pos = (target_px_h - 1 - y) * mm_per_pixel
if y % 2 == 0:
# Left to right
f.write(f'G0 X0 Y{y_pos:.3f}\n')
for x in range(target_px_w):
pixel = pixels[y * target_px_w + x]
power = min_power + int((max_power - min_power) * (255 - pixel) / 255)
f.write(f'G1 X{x*mm_per_pixel:.3f} S{power}\n')
else:
# Right to left
f.write(f'G0 X{actual_mm_w:.3f} Y{y_pos:.3f}\n')
for x in range(target_px_w-1, -1, -1):
if y % 50 == 0:
print(f" Row {y+1}/{target_px_h}")
# VERTICAL PASSES
if cross_hatch.lower() == 'y':
f.write('\n; --- VERTICAL PASSES (CROSS-HATCH) ---\n')
print("\nGenerating vertical passes...")
print("DEBUG: This should engrave on the way UP, not on the way DOWN!")
x_pos = x * mm_per_pixel
if x % 2 == 0:
# Even columns: bottom to top (engrave on the way UP)
f.write(f'G0 X{x_pos:.3f} Y0\n')
# We want to go from Y=0 to Y=max
# Read pixels from BOTTOM (image row target_px_h-1) to TOP (image row 0)
for step in range(target_px_h):
# step: 0 to target_px_h-1 (bottom to top in machine coords)
# image_y: target_px_h-1 to 0 (bottom to top in image)
image_y = target_px_h - 1 - step
pixel = pixels[image_y * target_px_w + x]
current_y = step * mm_per_pixel # 0 to max
f.write(f'G1 Y{current_y:.3f} S{power}\n')
else:
# Odd columns: top to bottom (engrave on the way DOWN)
f.write(f'G0 X{x_pos:.3f} Y{actual_mm_h:.3f}\n')
# We want to go from Y=max to Y=0
# Read pixels from TOP (image row 0) to BOTTOM (image row target_px_h-1)
# step: 0 to target_px_h-1 (represents position from top)
image_y = step # 0 to target_px_h-1 (top to bottom in image)
current_y = actual_mm_h - (step * mm_per_pixel) # max to 0
if x % 50 == 0:
print(f" Column {x+1}/{target_px_w}")
# End program
f.write('\n; --- END ---\n')
f.write('M5\n')
f.write('M2\n')
print(f"\n✅ G-code written to: {output_file}")
# Show sample of vertical section
if cross_hatch.lower() == 'y' and os.path.exists(output_file):
with open(output_file, 'r') as f:
lines = f.readlines()
# Find vertical section
for i, line in enumerate(lines):
if 'VERTICAL PASSES' in line:
print("\n=== SAMPLE OF VERTICAL SECTION ===")
# Show first 20 lines of vertical section
for j in range(i, min(i+20, len(lines))):
print(f" {lines[j].rstrip()}")
print("...")
break
return 0
except Exception as e:
print(f"\n❌ ERROR: {e}")
import traceback
traceback.print_exc()
return 1
if __name__ == "__main__":
sys.exit(main())
PYTHON_EOF
# Run the Python script
python3 /tmp/laser_final_fix.py \
"$png_file" \
"$target_width_mm" \
"$dpi" \
"$feed_rate" \
"$safe_z" \
"$engrave_z" \
"$min_power" \
"$max_power" \
"$cross_hatch" \
"$gcode_file"
result=$?
echo ""
if [ $result -eq 0 ]; then
echo "CONVERSION COMPLETE!"
echo "File: $gcode_file"
echo ""
else
echo "CONVERSION FAILED!"
fi
echo ""
#!/bin/bash
echo ""
# Get filename
# Find the file
else
exit 1
fi
echo ""
# Get settings
echo ""
echo "DPI: $dpi"
echo ""
echo "Cancelled."
exit 0
fi
echo ""
import sys
import os
def main():
return 1
# Parse arguments
try:
# Load image
if img.mode != 'L':
# Resize
# Generate G-code
# Header
# Setup
# Initialize
f.write('M3\n\n')
# HORIZONTAL PASSES
if y % 2 == 0:
# Left to right
else:
# Right to left
if y % 50 == 0:
# VERTICAL PASSES
if x % 2 == 0:
else:
if x % 50 == 0:
# End program
f.write('M5\n')
f.write('M2\n')
print("...")
break
return 0
import traceback
return 1
sys.exit(main())
PYTHON_EOF
"$png_file" \
"$dpi" \
"$feed_rate" \
"$safe_z" \
"$engrave_z" \
"$min_power" \
"$max_power" \
"$cross_hatch" \
"$gcode_file"
result=$?
echo ""
echo ""
else
fi
echo ""
26 Feb 2026 12:58 #343530
Pasting this into the message body has destroyed the indentation. As it contains embedded Python this means that it won't work at all.
Can you attach the script as a file instead?
(I tried correcting the file, but it became too difficult in the Python code without doing real code analysis)
Time to create page: 0.144 seconds
