Arc failing
19 Nov 2018 19:15 #121018 by jayy24
Arc failing was created by jayy24
can manually make cuts but when trying to cut a saved piece on the computer it goes to where it needs to touches the metal and ten says arc fail. have tried every g code i have read through the mdi and still cant figure how to get it to cut and stop saying arc fail.
19 Nov 2018 21:34 #121027 by rodw
Replied by rodw on topic Arc failing
You need to give us a lot more info. Which config, which thc, what probing routine etc.
Time to create page: 0.160 seconds
