Error, Probe Tripped During Non-Probe MDI Command
- EW_CNC
- Thank you received: 33
20 Dec 2018 16:59 #122646
by EW_CNC
Error, Probe Tripped During Non-Probe MDI Command was created by EW_CNC
Hi, I am having trouble with getting the error "Probe Tripped During Non-Probe MDI Command" during plasma touchoff.
I get it at random throughout the touchoffs in a file. It will not always trip on the same touchoff.
I have remapped F feed, is the probe G38.2 Z-0.75 F10. with F10 on the same line making the error?
I am using Axis with the touchoff posted in my g code file.
Should I be switching to a touchoff component?
Following is my touchoff code.
( ---- NEXT CUT ---- )
N012 G00 X0.754 Y3.456
N013 M67 E1 Q10
N014 G01 Z0.3
N015 G38.2 Z-0.75 F10.
N016 G91
N017 G01 Z0.15 F200.
N018 M3 S1
N019 M66 P0 L1 Q2
N020 G04 P0.2
N021 G01 Z-0.09
N022 G90
N023 G92 Z0
N024 G00 X0.754 Y3.456
N025 G01 X0.792 Y3.374 F138.8
E.W.
N013 M67 E1 Q10
N014 G01 Z0.3
N016 G91
N018 M3 S1
N019 M66 P0 L1 Q2
N020 G04 P0.2
N021 G01 Z-0.09
N022 G90
N023 G92 Z0
E.W.
- Thank you received: 2173
21 Dec 2018 15:31 #122707
Replied by cmorley on topic Error, Probe Tripped During Non-Probe MDI Command
Is your probe actually tripping when it is not supposed to?
Chris M
Chris M
- EW_CNC
22 Dec 2018 01:10 #122740
by EW_CNC
Replied by EW_CNC on topic Error, Probe Tripped During Non-Probe MDI Command
No, The probe comes down during touchoff, makes contact and stops giving the error code "Probe Tripped During Non-Probe MDI Command". If I go to the beginning of the touchoff and try again "Run From Here" sometimes it will give the error again and sometimes it will resume with no problem. It isn't doing it with each probe. Roughly 1/3 of the touchoffs.
- Thank you received: 4140
22 Dec 2018 01:19 #122742
Replied by rodw on topic Error, Probe Tripped During Non-Probe MDI Command
It is an error if the probe signal is triggered other than under G38 control. This can happen if the material moves during touchoff or warps and the probe is triggered when it shouldn't. Otherwise look for wiring faults or noise.
- Thank you received: 4648
23 Dec 2018 22:07 #122801
Replied by andypugh on topic Error, Probe Tripped During Non-Probe MDI Command
This sounds like noise or a momentary switching of the probe.
Using the HAL debounce on the probe input pin might be worth trying.
Time to create page: 1.057 seconds
