Monitor for plasma
  • JTknives
  • JTknives's Avatar Topic Author
  • Elite Member
  • Elite Member
28 May 2019 18:11 #135185 by JTknives
Monitor for plasma was created by JTknives
I am in search for a monitor for my plasma. I'm also very frustrated with using a keyboard and mouse (tiny touch pad on key board). I am wanting to upgrade to a touch screen but i know there are some frustrations i came across with using them or trying to get them to connect. I was wanting Elo brand as thy seam to be sealed rather well and would handle a shop environment. i had also considered getting the glass zero bezel version. Any of you guys use a touch screen or have advise on what i should get? Thanks
28 May 2019 23:08 #135219 by andypugh
Replied by andypugh on topic Monitor for plasma
forum.linuxcnc.org/54-user-exchange/3662...with-linuxcnc#134461
Probably the wrong continent, but it might be worth finding out what they are.
30 May 2019 12:32 #135381 by BigJohnT
Replied by BigJohnT on topic Monitor for plasma
I had an ELO on my mill but the image got blurry so I replaced it with this one.
www.amazon.com/gp/product/B01N4U7E7H
It's just a normal monitor but works ok for me, the touch part is connected with a USB plug.
JT
  • JTknives
  • Elite Member
  • Elite Member
06 Jun 2019 09:09 #136024 by JTknives
Replied by JTknives on topic Monitor for plasma
I bought a 22” Elo 2201L wife screen touch monitor. It should be delivered tomarow. Is there anything I should know about interfacing this display with Linux?
06 Jun 2019 11:19 #136030 by pl7i92
Replied by pl7i92 on topic Monitor for plasma
depending on what os you are it might need a display driver but it shoudt work out of the box on stretch
  • JTknives
  • Elite Member
  • Elite Member
06 Jun 2019 20:00 #136084 by JTknives
It ran right out of the box. No calibration or anything, just perfect in every way. I could not be happier and the larger 22” wide screen fits the GUI much better. Thanks guys - JT
  • JTknives
  • Elite Member
  • Elite Member
06 Jun 2019 20:02 - 06 Jun 2019 20:04 #136085 by JTknives
Last edit: 06 Jun 2019 20:04 by JTknives.
07 Jun 2019 07:14 #136178 by rodw
Replied by rodw on topic Monitor for plasma
Just curious. How usable do you find the 16:9 screen with Gmocappy?
I don't like it myself and rarely run it full screen.
07 Jun 2019 07:53 - 07 Jun 2019 07:54 #136181 by phillc54
Replied by phillc54 on topic Monitor for plasma
I reckon a display that size and aspect ratio would be a good candidate for having the plasma run tab reworked and put on permanent display on the left hand side.
Maybe I should revisit that as an option...
Cheers, Phill.
Last edit: 07 Jun 2019 07:54 by phillc54.
07 Jun 2019 08:34 #136183 by rodw
Cheers, Phill.
I reckon Phill should offer to build a plasma screen for the cool GUI Lcvette et al are working on... Then you have the 16:9 layout already done. Gmoacappy and Axis are really designed with 4:3 monitors in mind.
forum.linuxcnc.org/41-guis/34996-another-gui-project-underway
Time to create page: 0.253 seconds
