Plasma-Specific Docs
- Thank you received: 4654
11 Jun 2019 10:57 #136582
Plasma-Specific Docs was created by andypugh
We have a
lathe specific
documentation section here: linuxcnc.org/docs/2.8/html/ under "General User Information"
I suspect that it would make sense to have a similar section for Plasma users. Explaining what needs to be set up for a plasma, what a THC is and what the options are, use of Plasmac etc.
Does anyone feel like writing it? I have never even touched a plasma torch, so feel underqualified.
Also, I think that, as a standalone HAL component plasmac satisfies the criterion "can not break existing configs" and should be acceptable for merge in to 2.8. But that decision would have to be made by the release manager.
- Grotius
- Thank you received: 2349
11 Jun 2019 11:15 #136584
by Grotius
Replied by Grotius on topic Plasma-Specific Docs
Hi Andy,
That's for sure.
I think the coder of Plasmac can write documentation for it the best.
Me personally need the time hardly to release a dxf2gcode C - C++ program.
But i can provide library documentation, like plasma handbook's, cut chart's, etc. But we need to expand the forum attachment file size for this.
That's for sure.
- Thank you received: 4149
11 Jun 2019 12:13 #136589
I'm not sure its useful to add plasmac to 2.8 when it depends on reverse run which is in v2.9. If the V 2.8 release is only a few weeks away, it won't be too hard for a user to deploy a plasma machine from master branch. But I guess the component could be included.
i might be prepared to produce the content but would like to see someone else to format it into the HTML docs. I was thinking along the lines of a Google Drive document that could be shared with other authors becasue some areas might be out of my expertise. I'm sure Phill has a role in this.
I also think these docs should be restricted to reference material in the official linuxcnc ecosystem. Previously plasma content has been spread through various private web sites and forum posts. Its time to get it in the mainstream.
Replied by rodw on topic Plasma-Specific Docs
We have a lathe specific documentation section here: linuxcnc.org/docs/2.8/html/ under "General User Information"
11 Jun 2019 12:29 #136594
Allow me to undermine your excuses
There is no need to format into HTML, the LinuxCNC docs are written in the asciidoc format and look like this:
raw.githubusercontent.com/LinuxCNC/linux...lathe/lathe-user.txt
This is a format designed to be human-readable that is then parsed automatically in to HTML and PDF by the LinuxCNC build system.
If you create the file on github with a .adoc extension then it will be automatically rendered in pretty form by github. Or there are online renderers, or you can pass the file to asciidoctor locally.
But just plain-text content and explanatory images would be a good start.
Replied by andypugh on topic Plasma-Specific Docs
11 Jun 2019 13:16 #136603
I saw you getting your house in order on the developers mailing list before the undermining commenced.
- BigJohnT
- Thank you received: 994
12 Jun 2019 00:10 #136679
by BigJohnT
Replied by BigJohnT on topic Plasma-Specific Docs
At this point any docs need to be .txt, I've not got .adoc to build. And like Andy said asciidoc is just plain text files with a few rules for links, code, etc., a guide is in the docs directory for those rules.
JT
JT
23 Jun 2019 04:03 - 02 Jul 2019 05:37 #137636
Well here is a PDF of the proposed docs Andy requested. All 13 pages of it!
Several people on the forum have reviewed (and contributed) to the content.
At this point, to ensure we have original content, I need help to redraw 3 diagrams:
1. The first one.
2. The Second one
3. The hand drawn one (I'm no artist!)
So if there are any volunteers to take on this task, please step forward on this thread.
The document has been created in Google drive and it will be easy to download it as text and I have kept copies of all of the images.
Its not too late to make suggestions or request revisions.
UPDATED DOCUMENT 7 July 2019 - Final pending publishing in the 2.9 docs.
1. The first one.
2. The Second one
Last edit: 02 Jul 2019 05:37 by rodw. Reason: Final example
- Clive S
- Thank you received: 486
23 Jun 2019 08:36 #137641
by Clive S
Replied by Clive S on topic Plasma-Specific Docs
Rod . I am a bit dyslexic but I think I found a couple of errors.
Page 6 "Ohmic sensing relays on contact" should this be relies
Page 10 re mesa card 7i92 did you mean 7i96
Page 11 "firing 2 or 3 of them in series" did you mean "fitting"
I really do appreciate what you and the others have done with this project.
23 Jun 2019 08:55 #137642
Clive, thanks I've made those changes in the master document. The 7i96 seems to be the one others are using so thanks for that.
Its been a long journey for me as I knew nothing about plasma when I started my project . I think there is so much mis-information so I think this covers off on all of the stuff I know If anyone else spots any more typos or thinks I'm telling any lies, please give me your feedback so we can get this into the official docs for everybody.
- bevins
- Thank you received: 338
23 Jun 2019 09:07 #137643
by bevins
Replied by bevins on topic Plasma-Specific Docs
Rodw, thats fantastic. Nice writeup.
Is there going to be a section on hal pins and how this plasmac beast works? Configs and such?
Time to create page: 0.746 seconds
