nertajet hp125
- vre
- Thank you received: 17
06 Jul 2019 08:29 #138726
by vre
nertajet hp125 was created by vre
- pl7i92
- Thank you received: 358
06 Jul 2019 14:31 #138737
by pl7i92
Replied by pl7i92 on topic nertajet hp125
yes yiu can use generic
i woudt go for a P125
if you only plan to use sheets
go for a P80 Torch
www.ebay.de/sch/i.html?_from=R40&_trksid...w=P80+torch&_sacat=0
if you are in Europa
better to use a new one Plasma from Stamos are very good we use in Dayly 8hr shifts
there are 2 Different CABLE sizes be shure to fit yours
www.stamos-schweissgeraete.de/de/Plasmaschneider
go for a P80 Torch
- vre
06 Jul 2019 15:35 #138740
by vre
Replied by vre on topic nertajet hp125
Where can i find ocp-150 torch in europe?
- pl7i92
06 Jul 2019 15:39 #138741
by pl7i92
why using a ocp torch
use a P80 for up to 20mm of cutting thickness
that fits most of your need
and it is very cost effective as the nozzle sets are cheep and fast available
- vre
06 Jul 2019 15:43 #138742
by vre
Where can i find in europe cheap ocp-150 torch ?
- pl7i92
06 Jul 2019 15:59 #138744
by pl7i92
Abicor Binzel ABIPLAS CUT 150 Plasma Cutting Torch
woudt fit your request
but it is not requirerd for standard work
wast of money in my view
we run a shop with 5 plasmas
- Thank you received: 7488
06 Jul 2019 17:27 #138751
Get the Autocut 141 or even better A161. Also the consumables are very cheap at 4.6 euro per set again with all the tax and other stuff.
First check how many air hoses go to the torch, if it is only one, you are all set.
Replied by tommylight on topic nertajet hp125
Trafimet in Italy, torch with 12m cable for 470 euro with transport, 19 % tax and 10 % customs, torch only with all the parts for 180 euro.Where can i find in europe cheap ocp-150 torch ?
- vre
06 Jul 2019 19:59 #138755
by vre
ocp-150 is the original torch of nertajet hp125
but if this plasma works with cheaper torch i will use the cheaper.
Something else..
cutting need extra gasses like O2 or N2 or H2 or simple air works ?
Something else..
06 Jul 2019 20:13 #138756
All of them will work with plain air.
Some might need some plumbing, literaly.
- pl7i92
07 Jul 2019 17:51 #138808
by pl7i92
the plasma is well over the top for a standard user
if you dont plan to cut X5 + V4A at 20mm thickness it is not the best guess as you will be in trouble with the electronics soon
thats maybe the case this is sold for that price
newer Plasmas as of 85Amps are mutch powerfull at very low cost
with high cnc performence
Time to create page: 0.415 seconds
