Master Branch 2.9, Plasmac files missing
- LinfieldGarage
- Thank you received: 11
30 Jul 2019 20:05 #140975
by LinfieldGarage
Master Branch 2.9, Plasmac files missing was created by LinfieldGarage
Hello All,
I couldnt find the answer through searching or in the Plasmac manual.
I had installed Plasmac from source on LinuxCNC 2.7, and it worked but had some bugs so I copied all of those files to a backup directory, and installed Master Branch through the Synaptic package manager. It works again using my old config files, but the Plasmac configurator and all associated files are not in either of the directories mentioned in the manual.
I was able to run the configurator.py from my backup directory but that only complicates things by creating a bunch of links back to the original directory. I want to start with the cleanest possible install before getting into customizing Plasmac and running the machine.
Has anyone seen this before? Should I copy the Plasmac files to the new Linuxcnc directory?
Thanks,
Jamie
Thanks,
Jamie
- phillc54
- Thank you received: 2100
31 Jul 2019 00:06 - 31 Jul 2019 00:45 #140980
by phillc54
Replied by phillc54 on topic Master Branch 2.9, Plasmac files missing
If you open your Applications Menu then CNC and then LinuxCNC do the PlasmaC sim configs appear in the Configuration Selector under Sample Configurations - by_machine - plasmac
Edit:
From a terminal what does the following return:That is assuming you are using master-rtpreempt, if not leave the -uspace off
Edit:
apt-cache policy linuxcnc-uspace
Last edit: 31 Jul 2019 00:45 by phillc54.
- LinfieldGarage
01 Aug 2019 12:11 #141097
by LinfieldGarage
Replied by LinfieldGarage on topic Master Branch 2.9, Plasmac files missing
Thanks Phil,
The Plasmac samples opened and copied to my home directory as you described.
I also found the configurator.py in the correct folder like the manual suggests: /user/share/doc/linuxcnc/examples/sample-configs/by_machine/plasmac/configurator.py
Not sure why I couldn't find it before.
Thanks for the help,
Jamie
Jamie
