- Thank you received: 13
Stefan's plasma with toma_thc and Proma THC150
- thefabricator03
- Visitor
7 years 1 month ago #144878
by thefabricator03
Replied by thefabricator03 on topic Stefan's plasma with toma_thc and Proma THC150
I am the other plasma Stefan, Tom thought it was my site.
You should check out the PlasmaC configuration, It is very stable and we are adding new features to it all the time.
- HomemadeNJ
7 years 1 month ago #144880
by HomemadeNJ
Replied by HomemadeNJ on topic Stefan's plasma with toma_thc and Proma THC150
I've taken a peek at PlasmaC and it looks fantastic, havent had the time to tinker with it yet. It's hard to switch as I have so much time invested in the Proma config. I've been adding features to it over time as well.
- THC disable via UI or Custom M code
- Move to cut height after pierce delay elapsed
- Ohmic sensing integration
- Secondary probe speed
- Simulation mode
- Added the THCAD10 without using the THC component, just ran values through wcomp. Etc..
Just finished the air scribe mode using the Z to move the scribe. Used a few mux gates and custom M codes to pass user selectable heights to the travel height field. Works great.
- Simulation mode
- thefabricator03
- Visitor
7 years 1 month ago #144881
by thefabricator03
PlasmaC has all those except secondary probe speed, What is that?
- Thank you received: 4153
7 years 1 month ago #144894
We will have to call you Stefan03 from here on.
Stefan01, several of us have thrown out hundreds of hours of work and gave Plasmac a go and we never went back...
If you have the THCAD and a 7i96 you will never use your Proma again....
Replied by rodw on topic Stefan's plasma with toma_thc and Proma THC150
thefabricator03 wrote: PlasmaC has all those except secondary probe speed, What is that?
The following user(s) said Thank You: tommylight, thefabricator03
- Thank you received: 7491
7 years 1 month ago #144946
Replied by tommylight on topic Stefan's plasma with toma_thc and Proma THC150
Stefan03 thank you, those are very nice machines.
The development of PlasmaC was a rolocoaster ride but i was hanging with one hand only and flapping around watching the others do a great job of making it and Linuxcnc the definitive plasma solution.
Thank you, all.
P.S.
Where is Stefan02?
Thank you, all.
P.S.
Where is Stefan02?
7 years 1 month ago #144948
He want mad so we shot him!
tommylight wrote: Where is Stefan02?
Time to create page: 1.327 seconds
