- Hardware & Machines
- CNC Machines
- Plasma & Laser
- Possible to use output Mesa 7i76e with buck converter to 5V to use thcad-5...
- CNCFred
- Thank you received: 43
22 Jan 2020 02:21 #155411
by CNCFred
Possible to use output Mesa 7i76e with buck converter to 5V to use thcad-5... was created by CNCFred
I am just curious if it is possible to use the output of the Mesa 7i76e with buck converters to 5V(E. g. From 24V) to power a cross line laser or the thcad-5.
It would eliminate the usage of using relais instead.
- Thank you received: 5336
22 Jan 2020 08:38 #155426
Replied by PCW on topic Possible to use output Mesa 7i76e with buck converter to 5V to use thcad-5...
You would typically power a THCAD from the encoder connectors 5V
The following user(s) said Thank You: CNCFred
- Thank you received: 4155
22 Jan 2020 12:29 #155441
As described in the Plasma primer here linuxcnc.org/docs/devel/html/plasma/plas...l#_thcad_connections.
When I added a cross line laser I stepped down 24 volt with a $3 variable power supply from ebay. I don't think I'd like to power it off the 7i76e as it trips a limit switch when its powered on so it must draw a bit of power.
Replied by rodw on topic Possible to use output Mesa 7i76e with buck converter to 5V to use thcad-5...
- CNCFred
22 Jan 2020 12:35 #155443
by CNCFred
Replied by CNCFred on topic Possible to use output Mesa 7i76e with buck converter to 5V to use thcad-5...
OK... That is easier I admit...
Thank you!
Thank you!
- CNC Machines
- Plasma & Laser
Time to create page: 0.710 seconds
