how to invert float-switch bevor fed in debounce
  • CNCFred
  • CNCFred's Avatar Topic Author
  • Elite Member
  • Elite Member
17 Mar 2020 07:02 - 17 Mar 2020 07:02 #160542 by CNCFred
How do I invert the switch before it is fed in debounce??
net plasmac:float-switch hm2_7i76e.0.7i76.0.0.input-08 => debounce.0.0.in
I could change hardware but better would be soft...also need to change the breakaway, is no at the moment because closed :-)
set like this just somewhere in hal?
setp hm2_7i76e.0.7i76.0.0.input-08.invert_output true
another question in plasmac the multitool does not open..
thank you again ....!!!
Last edit: 17 Mar 2020 07:02 by CNCFred.
17 Mar 2020 07:20 #160546 by rodw
If you review in halshow, there should be a pin like
hm2_7i76e.0.7i76.0.0.input-08-not
Just use that pin for the inverse.
The following user(s) said Thank You: CNCFred
17 Mar 2020 10:47 - 17 Mar 2020 10:51 #160567 by PCW
If you have a question about available hardware pins for Mesa cards, you can list every
available pin and parameter ( plus their current values and connections ) by typing this
command in a terminal window when LinuxCNC is running:
halcmd show all hm2
If you want to save the list for later use (say for copy pasting from the list when editing
a hal file) you can redirect the listing to a file:
halcmd show all hm2 > mesapins.txt
And if you want to show all pins,parameters, and values of all LinuxCNC components:
halcmd show all
Last edit: 17 Mar 2020 10:51 by PCW.
  • CNCFred
  • Elite Member
  • Elite Member
17 Mar 2020 11:50 #160575 by CNCFred
Thank you,
I have seen in halcmd these inverted pins and understand now that theses are provided beforehand for my 7i76e!
checked my machine.hal and found
net max-y2 <= hm2_7i76e.0.7i76.0.0.input-27-not, perfect
Still more questions:
A:I would like to start plasmac without being connected to my machine to checkout different tabs and see what can be configured.
is that possible ??
B: I need to activate an output pin for relay to start my crosslaser, should I do that on buttons in plasmac or do I need to install pyvcp panel?
thank you again for your help..
  • CNCFred
  • Elite Member
  • Elite Member
17 Mar 2020 15:30 #160590 by CNCFred
I tried to setup axis with pyvcp and then configured plasmac again new.
It removed the pyvcp panel.
so it seems it is not possible to add pyvcp to plasmac....
17 Mar 2020 19:01 #160604 by phillc54
is that possible ??
Just run one of the PlasmaC simulations from the config picker in Sample Configurations - by_machine - plasmac
I don't think PyVCP and GladeVCP play well together.
There are some user buttons on the main screen as well as in the Extras Panel which would work well for what you want.
linuxcnc.org/docs/devel/html/plasma/plas...#custom-user-buttons
  • CNCFred
  • Elite Member
  • Elite Member
18 Mar 2020 00:46 - 18 Mar 2020 00:46 #160614 by CNCFred
I wanted to configure My machine for use and on the kitchen table :-)
I knew about the buttons but thought a tick box to enable, disable out pins is easier then via gcode and using two buttons on & off
So buttons it is.
Thank you!
Last edit: 18 Mar 2020 00:46 by CNCFred.
18 Mar 2020 01:11 #160616 by phillc54
You could make a copy of your config and setup the hal file as a sim and enable the test panel in the ini file.
So buttons it is.
Thank you!
I guess in hindsight I could have kept the Flood and Mist checkbuttons somewhere on the screen and made the label customisable...
  • CNCFred
  • Elite Member
  • Elite Member
18 Mar 2020 02:39 #160629 by CNCFred
I have to skip finding that out how to.... (linuxcnc" like opening a can of worms") :-)
still struggling with getting gcode for plasmacutting (fusion 360 & pre processor)...
Enabling out pin via gcode
(swolebro has a video about it.. forum.linuxcnc.org/47-hal-examples/38440...-9-part-video-series)
Setting up the buttons..
Setting up plasmac... Settings for cutting.. Velocity etc.
Phillc54 thank you for your work! & help
Time to create page: 0.124 seconds
