Apparent Step Errors
- jnwinkie
09 Apr 2020 00:48 #163260
by jnwinkie
Replied by jnwinkie on topic Apparent Step Errors
Thanks for the link Tommy;
If I used a 4:1 reduction do you reckon that would get me into the ball park?
Cheers
Cheers
- Thank you received: 7488
09 Apr 2020 01:34 #163275
Replied by tommylight on topic Apparent Step Errors
That would bring it to 2.5CM per revolution, so right in the sweet spot for plasma when using steppers as you can still achieve decent velocities for rapids. Even 1:3 will do just fine, there are some very cheap ones using T2 belt and 20:60 pulleys on ebay, seller is "ideaformer", i got 6 of them from him and some other stuff, he is the only one i never had issues with delays, and almost always provides a valid tracking number. BTW, they are under 5$ per set, if i remember correctly, just be sure to select the inner holes for your needs.
The following user(s) said Thank You: jnwinkie
