Clive S wrote:
rodw wrote: What made it pause?
Yes. The warp upwards, I just had to press pause again and it carried on. The first one cut without issue.
thefabricator03 wrote: I would say the material warping tripped the float switch.
phillc54 wrote: #1 and #2 are the same cut beginning and ending at the bottom centre but with reverse direction. The step in them looks to me like a classic case of backlash. It looks like the fourth leg of the cut (Y direction) has come up short.
#2 and #2b are identical but with the Y motors swapped around. The step in #2b looks a bit more pronounced but that may be the picture resolution.
#3 and #4 are the same cut beginning and ending at the left centre but with reverse direction.
#3 looks to me like backlash. It looks like the fourth leg of the cut (X direction) has come up short.
#4 doesn't make sense to me at all, the fourth leg of the cut (X direction) has grown... Are you sure that wasn't a repeat of #3?
I think your table is possessed :evil:
Back in the dark old days I would of drilled two holes either end with a hole saw and cut the center out with a 1mm grinding disc by hand. Having our CNC machines sure makes things easy!
To me, #1 and #2 look like Y backlash or missed steps in one direction, but then #3 and #4 have me confused....dvn4life1972 wrote: I thought the test you had me do ruled out backlash...?
I agree, I don't think it is a software issue, now all we need to do is find out what it is.I'm pretty certain at this point it isn't a software issue. I finally got a brand new config built for this different PC and that's what I cut those squares from yesterday. So that eliminates the possibility of some error in a config jumping across to a new PC by using the same files from the laptop.
