My Newb Plasma Table Attempted Build
6 years 3 months ago #173914 by dvn4life1972
I have 2. They're sisters/litter mates, a little over 2 years old. Much better behaved than our human kids lmao!
6 years 3 months ago #174541 by dvn4life1972
Had to take a break. I herniated a disc in my back last week. Anyway, I'm feeling a little bit better and decided to get something done today.
Took all of the table apart down to the frame. I never had got around to painting it, and a little bit of surface rust has begun to settle on the frame. This is the perfect opportunity to correct that and put some protection on it. Also added a couple of pieces of square tube to the bottom for more leg support. I've been wanting to add something that I could place my plasma on, and I had this angle iron laying around in the garage so I just used two pieces. I'll probably get some expanded metal for both sides of the angle iron so I have a complete bottom storage area.
Tomorrow it will get a mount point for the new electronics enclosure and then the paint. It's 106 deg F put right now, so I think I've had quite enough for today.
  • thefabricator03
  • New Member
  • New Member
6 years 3 months ago #174680 by thefabricator03
Replied by thefabricator03 on topic My Newb Plasma Table Attempted Build
Its pretty cool seeing these small uncomplicated table designs. It goes to show that keeping it simple can still work.
6 years 3 months ago #174681 by rodw
thefabricator03 wrote: Its pretty cool seeing these small uncomplicated table designs. It goes to show that keeping it simple can still work.
Hmm, I wonder if dvn4life1972 actually still thinks its uncomplicated having got this far!
But yes, agree you can do it quite cheaply....
The following user(s) said Thank You: dvn4life1972
6 years 3 months ago #175008 by dvn4life1972
My back is feeling a little bit better, so I rearranged the small space I have and can now begin v2.
The gantry riser plates I made seem to be in good order, only got this side partially assembled and I was able to mount the rails to the 3030 extrusion that makes the gantry beam.
The following user(s) said Thank You: phillc54, thefabricator03
  • thefabricator03
  • New Member
  • New Member
6 years 3 months ago #175009 by thefabricator03
Thats a pretty interesting way to mount the linear rails.
