- Thank you received: 17
Ohmic sensing, what's best to use ?
- jay1st
- phillc54
- Thank you received: 2100
- Thank you received: 4153
jay1st wrote:
rodw wrote: That depends. You have no idea how hard it was coming up with it! Be sure to learn how to use halcompile and write your own components. A lot of fun and Linuxcnc's best kept secret! I love it...
That is where i lack comptency, coding and understanding the codes !
I can do some stuff with an arduino, but C and Py is too much for me, i need to grasp how the HAL system works and so on...
If you are coding an Arduino Sketch, you are programming in C. Think of the LCNC servo thread as being the loop() function in Arduino and a component as being a function called from the loop() and you are in business.
- phillc54
That is a neat way of looking at it.rodw wrote: [If you are coding an Arduino Sketch, you are programming in C. Think of the LCNC servo thread as being the loop() function in Arduino and a component as being a function called from the loop() and you are in business.
Well technically, the servo thread is an Interrupt Service Routine (ISR) attached to the timer interrupt so it would be a timer interrupt in Arduino speak... If you have not used interrupts (both timers and hardware) with your Arduino scripts you have not lived!. Hardware is great to read encoders and timers interrupts are great for stepper step generators.
- jay1st
ssudl.solent.ac.uk/id/eprint/3497/1/Test results for a capacitance-based corrosion sensor - BINDT 10-10-2016.pdf
