GYS 40FV + THCAD-10 wiring
19 Jul 2020 09:56 #175130 by Mud
GYS 40FV + THCAD-10 wiring was created by Mud
Where would it be recommended to tap into this plasma cutter to gain the arc voltage signal? I have only partial understanding of this machine, so am not confident where is common (and don't really want to test my theories with live voltage!). Am I simply after HT- and HT+, and connect wherever convenient? If they are equivalent I'm tempted to use piggyback spade connectors on the HT-/HT+ to the right of the photograph/schematic for reversibility. I don't want to mess with the (assumedly) higher current connections at the front of the machine if I can help it.
I have 2W 500V metal film 1 megaohm resistors to stick on the negative and positive sides, which I will fit inside the case, sending out only the reduced signal to the THCAD which is mounted in the control cabinet.
My plan is to run the switch and signal through a single multi-core 0.5mm^2 CY cable back to the controller - I assume that's ok...let me know if that's a bad idea!
I have verified the switch on the torch is doing what I expect and it is simply connected via spades which I can nicely piggyback off (or discard the torch switch altogether). I'm not sure what the 'safety' circuit which also goes out to the torch is doing though - initially I thought the torch had parallel NC+NO switching (or possibly a switch in the trigger guard), but actually the safety pair of wires just appears shorted irrespective of the trigger state.
Thanks in advance :)
19 Jul 2020 10:23 #175132 by tommylight
Replied by tommylight on topic GYS 40FV + THCAD-10 wiring
Do those thick coper wires go to the clamp and the torch ?
HT can not be used.
The following user(s) said Thank You: Mud
19 Jul 2020 10:32 #175133 by Mud
Replied by Mud on topic GYS 40FV + THCAD-10 wiring
I have added some labels on the attached image - it lines up well with the schematic.
19 Jul 2020 10:47 #175135 by tommylight
THCAD + to clamp
THCAD - to torch, the black thick one, not the red one. Never the red one.
Of course, resistors go to those terminals, then from resistors to THCAD.
19 Jul 2020 10:57 #175136 by Mud
I've added a detail shot of the torch black cable meeting the circuit board - do you think I can use the unoccupied male spade connector there? It appears (and tests as) common, and looking at the circuit board it appears to share the massive trace, but I also get continuity with the red so quite paranoid...!
19 Jul 2020 11:09 #175137 by tommylight
Yes you can use the empty spade connector, and it is OK that it has continuity to the red wire, but it can NOT be connected to the red wire, that is the high voltage pilot arc wire.
The reason it shows continuity with the torch wire is it goes through a transformer.
That "self" and "N" does not help at all, it is very confusing.
19 Jul 2020 11:12 #175138 by Mud
Awesome, I've been putting this job off for a while, but now confident enough to get on with it B)
19 Jul 2020 11:24 #175139 by tommylight
Just be careful, those are extremely dangerous.
Remove the cord before everything, and when testing, again remove the cord before getting your hands inside it or putting the lid on.
19 Jul 2020 13:06 #175142 by Mud
That's why I was putting it off! ;)
I think the surgery was a success - I've got ~2 meg across my signal output and the switch seems to function. Verification may have to come later, I'm not really set up for a cut.
18 Aug 2020 10:46 - 18 Aug 2020 10:49 #178592 by Mud
I'm getting ~10x the voltage I was expecting - the test here is just a multimeter, with me hand-cutting a bit of thin scrap metal (using a stand-off to set the cutting distance).
I checked if I had omitted a resistor, but that was not the case. Both resistors read around 0.99Meg. Is it because the multimeter has a crazy-high impedance, i.e. I need to connect a 100k resistor across the +/- and read the voltage across that?
The remote switch seems to function anyhow - about 4.3V across that (haven't checked current yet).
Last edit: 18 Aug 2020 10:49 by Mud.
Time to create page: 0.158 seconds
