Plasma "Slag" Skirt
- AgentWD40
- Thank you received: 96
06 Aug 2020 14:19 - 06 Aug 2020 14:20 #177510
by AgentWD40
Plasma "Slag" Skirt was created by AgentWD40
Does anyone here attach a dust shoe/boot/skirt to their plasma to knock down the slag / sparks? Of so what type of material would be appropriate for this skirt?
I was watching one of the crazy Colin Furze videos on youtube and happened to notice his cnc plasma had a slag skirt, I don't think I've ever noticed one a plasma before. Skip to 4:28
Thoughts?
Thoughts?
Last edit: 06 Aug 2020 14:20 by AgentWD40.
- snowgoer540
- Thank you received: 907
06 Aug 2020 14:32 - 06 Aug 2020 14:32 #177514
by snowgoer540
That dude is a crazy SOB! Cbear introduced me to these Silicone Funnel , you cut to fit around your torch, they seem to work well and since it's silicone don't burn up immediately. I moved from an Everlast to a Hypertherm and havent cut a new one yet, but it worked pretty good on the Everlast.
Replied by snowgoer540 on topic Plasma "Slag" Skirt
Thoughts?
Last edit: 06 Aug 2020 14:32 by snowgoer540.
The following user(s) said Thank You: AgentWD40
- Thank you received: 7488
06 Aug 2020 14:51 #177520
Replied by tommylight on topic Plasma "Slag" Skirt
I have used once that type of steel he is using in the video, it does not bend or move or warp at all!
Everything else will do so, so the shoe would interfere a lot.
- AgentWD40
07 Aug 2020 20:03 #177648
by AgentWD40
Replied by AgentWD40 on topic Plasma "Slag" Skirt
How about a piece of fire blanket?
- CBEAR
- Thank you received: 46
08 Sep 2020 11:58 #181256
by CBEAR
Replied by CBEAR on topic Plasma "Slag" Skirt
I've used a collapsible silicon cooking funnel that I bought off of amazon for years. They sell them in 2 and 4 packs. They work great! I know several people that now use them, all with good success. They can burn through if you're cutting material that's at the top of your plasma cutters cut capacity because of the extended periods of block back before a pierce, but they work great otherwise. I usually get 7-9 months of normal cutting out of them.
- AgentWD40
08 Sep 2020 14:38 #181291
by AgentWD40
If y'all wouldn't mind could @CBEAR or @snowgoer540 post a picture of how you've rigged your silicon funnel?
- snowgoer540
08 Sep 2020 17:51 #181307
by snowgoer540
I do not mind at all, I'll grab a pic when I get home tonight. Truthfully it's been off lately, but I'll slap er on there and snap a pic.
- snowgoer540
09 Sep 2020 10:33 #181408
by snowgoer540
Crap, I'm sorry. I got home to an air conditioner-emergency (clogged condensation port caused leaking into the wall down the inside of the wall, and out the steel I-Beam that spans the garage) and a few hours later when that was sorted out, I totally forgot about snapping a picture. I stuck a post-it note on my wallet as a reminder - I won't forget tonight.
- AgentWD40
09 Sep 2020 12:14 #181424
by AgentWD40
No worries! Water damage is no joke.
- Thank you received: 2176
09 Sep 2020 18:04 - 10 Sep 2020 06:50 #181479
Replied by Aciera on topic Plasma "Slag" Skirt
Last edit: 10 Sep 2020 06:50 by Aciera. Reason: Get the actual picture in
Time to create page: 0.348 seconds
