Cuts are not as designed
- Aldenflorio
- Thank you received: 15
25 Sep 2020 03:58 #183670
by Aldenflorio
Cuts are not as designed was created by Aldenflorio
I’m still fine tuning my newly “finished” plasma. So I’ve only really been cutting lines and basic shapes. My machine seems to have problems with circles though, they don’t match up and there’s just some weird lines going on. But it cuts squares perfect, it’s square, and it scaling is perfect. Could the issue be the design software? I’m using librecad, then dxf2gcode
- thefabricator03
- Visitor
25 Sep 2020 04:35 #183679
by thefabricator03
Replied by thefabricator03 on topic Cuts are not as designed
What kind of drive system does your machine use? Direct drive steppers?
- Aldenflorio
25 Sep 2020 04:58 #183681
by Aldenflorio
Replied by Aldenflorio on topic Cuts are not as designed
Direct drive with stepper motors is correct
- thefabricator03
- Visitor
25 Sep 2020 05:01 #183682
by thefabricator03
Have a look at this thread, forum.linuxcnc.org/plasma-laser/38777-ap...-step-errors?start=0
Particularly the post by tommylight.
- Thank you received: 7488
25 Sep 2020 08:25 #183692
Replied by tommylight on topic Cuts are not as designed
Pictures ?
- Aldenflorio
25 Sep 2020 12:47 #183713
by Aldenflorio
25 Sep 2020 13:25 #183714
One of the axis has backlash of about 1mm.
And please upload the pictures here, not on external sites.
- Aldenflorio
25 Sep 2020 13:28 #183715
by Aldenflorio
25 Sep 2020 13:30 #183717
while the machine is powered on and the motors are locked, move each axis by hand, they should not move. Also check the pulleys as one of them might be loose.
- Aldenflorio
25 Sep 2020 13:45 #183719
by Aldenflorio
It’s direct drive, so I have a gear rack and gears. I’ll check in a few hours. How would I fix that?
Time to create page: 0.330 seconds
