QtPlasmaC VS plasmaC
06 Apr 2021 01:38 - 06 Apr 2021 01:39 #205022 by motal2004
QtPlasmaC VS plasmaC was created by motal2004
What is the difference between the two?
Last edit: 06 Apr 2021 01:39 by motal2004.
06 Apr 2021 01:47 #205024 by rodw
Replied by rodw on topic QtPlasmaC VS plasmaC
QTplasmac is the active version moving forward. Plasmac won't be supported other than bug fixes..
06 Apr 2021 02:25 #205027 by motal2004
Replied by motal2004 on topic QtPlasmaC VS plasmaC
Wow!!! I can’t keep up lol. So is it worth switching?
06 Apr 2021 05:18 #205034 by robertspark
Replied by robertspark on topic QtPlasmaC VS plasmaC
I thought QtPlasmaC was the GUI, and PlasmaC was the underlying component.
is that not the case?
so QtPlasmaC (the GUI / front end) runs without a hal component?
06 Apr 2021 05:50 #205038 by phillc54
Replied by phillc54 on topic QtPlasmaC VS plasmaC
QtPlasmaC is a GUI (+ config) that uses the plasmac component.
PlasmaC is a set of VCP panels added to either the Axis GUI or Gmoccapy GUI (+ config) that uses the plasmac component.
Note: config refers to HAL connections plus helper files
Clear as mud... :)
06 Apr 2021 11:28 #205079 by snowgoer540
Replied by snowgoer540 on topic QtPlasmaC VS plasmaC
Browsing the two manuals may help you a bit at least visually:
QtPlasmaC
PlasmaC
In addition to what the others have already said, QtPlasmaC is a bit more seamless than PlasmaC loaded on top of Axis or Gmoccapy were since it's a purpose-built GUI.
Just a few noteworthy additions off the top of my head:
  • The Z axis DRO now displays relative to the material during cutting
  • There is an option to add a button that will trace the job you're about to cut at the extents (essentially draw a frame around it to see if any part is outside the material)
  • The ability to keep Z movements in a gcode file (in case you want to run a marker or similar)
  • The Z axis will automagically go near the top of travel when starting a job, before any X Y movements are made
  • Material alignment/X0Y0 via a laser
  • Material alignment/X0Y0 via a camera
Time to create page: 0.488 seconds
