how to do edge start with cnc plasma
- bevins
- Thank you received: 338
07 Apr 2021 12:13 #205246
by bevins
how to do edge start with cnc plasma was created by bevins
I have a customer that wants to cut 1" steel but the hyperterm says it needs to edge start at that thickness.
Is this possible to do with plasmac or is this more a CAM (sheetcam) issue?
- thefabricator03
- Visitor
07 Apr 2021 13:08 #205253
by thefabricator03
Replied by thefabricator03 on topic how to do edge start with cnc plasma
If I were trying to do this, I would create a sheetcam program with the lead in on the edge then in PlasmaC I would index the torch and touch off on the edge you want to start from.
07 Apr 2021 23:11 #205291
Tack a thin bit on overlapping the edge?
Replied by andypugh on topic how to do edge start with cnc plasma
- thefabricator03
- Visitor
08 Apr 2021 21:12 #205367
by thefabricator03
The way I find the edge of the sheet with PlasmaC is, I jog to the outside of the sheet and pulse the torch. Then jog in and you will notice a sound change with the air pressure hitting the sheet. On my water table this is easy.
I can always get the plasma to start right on the edge using this method.
- bevins
08 Apr 2021 23:18 #205383
by bevins
So you set toe xy0on the edge and then make sure sheetcam starts the cut there?
Replied by bevins on topic how to do edge start with cnc plasma
- thefabricator03
- Visitor
08 Apr 2021 23:27 #205386
by thefabricator03
Yeah, I just find the edge and touch off and start from there. Your SheetCAM program will start from the touched off point so just set a long enough lead in so your not cutting right along the edge for square parts.
Time to create page: 0.218 seconds
