Toroidal power supply and Gecko stepper questions
- Thank you received: 4151
20 May 2021 00:00 #209582
I went back through my notes and this is what they provided
au.rs-online.com/web/p/thermistor-ics/18...ALw_wcB&gclsrc=aw.ds
I just wired them up and it worked!
I am using a couple of 7 amp Moon Nema 34's for the Y axis, and a 2 amp NEMA 24's on the Y axis. I had planned to use another Sanyo Denki for the Z axis but it did not like the 6 amp driver I had so I'm still using a cheap Chinese Nema 23 on the Z. Lam said there would be a solution. Eventually I will swap out the drive for a 3 amp one. The Sanyo's punch well beyond their weight. They have very high rotational inertia (and torque) for the form factor.
Remember the Lams give full rated current not RMS per the normal motor sec so I am not giving the 34's the full 7 amps.
Replied by rodw on topic Toroidal power supply and Gecko stepper questions
I have not had much luck with thermistors, but it is pretty simple to do it with a resistor and a relay if you add a bit of magic. And that magic is HAL.
The following user(s) said Thank You: txtrone
- txtrone
- Thank you received: 106
20 May 2021 00:09 #209583
by txtrone
Thanks for the info Rod!
Replied by txtrone on topic Toroidal power supply and Gecko stepper questions
Time to create page: 0.762 seconds
