OXY FUEL CUTTING PIERCING DELAY
28 Jun 2021 07:43 #213097 by rajsekhar
OXY FUEL CUTTING PIERCING DELAY was created by rajsekhar
Hello..Everyone..I am new to Linuxcnc..I have set up a system that is running ok in X, Y, Z direction. It is running with a parallel port 5axis breakout board. If I connect spindle motor with VFD, that is also working fine with 0~10 V control for speed.
Now, I am planning for a similar arrangement for Oxy-Fuel cutting with SheetCAM to generate code. That is working in direction X, Y, Z but piercing is not working in CNC. The simulation in Sheetcam shows piercing delay, but no delay occur when running in Linuxcnc. The Gcode shows no delay command either. I can manually put any delay to the code, but that should not be the way for regular use.
How to incorporate piercing delay (delay time varies depending on plate thickness) to the system..Can anyone help?
  • rodw
  • rodw's Avatar
  • Platinum Member
  • Platinum Member
28 Jun 2021 08:06 #213104 by rodw
Replied by rodw on topic OXY FUEL CUTTING PIERCING DELAY
You probably need to modify the onPendown() method in the Sheetcam post processor and add an appropriate G4 Pn where n = the pierce delay defined in the selected Sheetcam toolset. Before PLasmac was developed, we plasma users used to use a touch off routine that was called from that method which included the delay.
Something like what BigJohnT shared here.
gnipsel.com/shop/plasma/plasma.xhtml
30 Jun 2021 04:40 #213305 by rajsekhar
Replied by rajsekhar on topic OXY FUEL CUTTING PIERCING DELAY
It worked perfect..Thanks lot
Time to create page: 0.307 seconds
