- Hardware & Machines
- CNC Machines
- Plasma & Laser
- Still get no arc detected error with THC from polabs
- Giuseppe
- Thank you received: 9
15 Aug 2021 09:39 - 15 Aug 2021 09:47 #217800
by Giuseppe
Replied by Giuseppe on topic Still get no arc detected error with THC from polabs
I think i have new knowledge.
I use a chinase BOB and the Polabs THC.
Now I have measured that 9 volts come out at the THC outputs. when I switch the individual outputs in the test mode of thc manuel, the voltage drops to 3 volts.
I think I have a mistake in thinking?
Can it work like that. if I attached the outputs directly to the inputs of the BOB?
Last edit: 15 Aug 2021 09:47 by Giuseppe.
- Giuseppe
15 Aug 2021 09:58 #217801
by Giuseppe
should i use somthing like a pullup resistor?
- Thank you received: 4149
15 Aug 2021 10:07 #217802
Replied by rodw on topic Still get no arc detected error with THC from polabs
I think I would add a relay so that +24v from the BOB power supply was sent to the input (assuming it is 24v compatible)
- Giuseppe
16 Aug 2021 17:07 #217898
by Giuseppe
Shame on me. The THC works fine. On the Inputpins the voltage is 9 Volt and drop to 0volt (3mV) when the signal from the THC comes.
It look like the BOB has a problem or LinuxCNC will sometimes hangon.
I will check.
I will check.
- Giuseppe
16 Aug 2021 18:48 #217911
by Giuseppe
Holy crap. I got it. I think so
It looks like one of the input pins are not working probably.
I changed the pin for arc ok and one of the up/ down signal.
Now the arc ok works and the up signal don't work.
I will try tomorrow some more cuts and look if the problem is solved.
But it looks so.
But it looks so.
The following user(s) said Thank You: phillc54, rodw
- CNC Machines
- Plasma & Laser
Time to create page: 0.413 seconds
