THC - out of ideas
- snowgoer540
- Thank you received: 907
Says the guy who insists on being on the "bleeding edge"...I just hope Phil and Greg pick a sensible point to stop the near daily updates to Qtplasmac leading up to this. It can't live in Development forever.
How is the development of MonoKrom coming along? I thought you had moved over to that.
- Thank you received: 4151
Isn't that the whole point of a development branch? Eventually it becomes the release version and the version number increment. It would be nice if this coincided with the Debian Bookworm release
Of course, but hopefully soon master branch will be 3.0 not 2.9
- phillc54
- Thank you received: 2100
What has that got to do with your complaint about updates?
- phillc54
In that case, what was the point of the above, QtPlasmaC will always be in the development branch and will always be updated.
Monokrom has stalled a bit due to lack of time both of mine and the developer. I do like it though and its core is fully functional.
But one has to be ambidextrous around here with configs.
The so called bleeding edge is required for driver support of my hardware in later kernels. I got bitten early in the piece with the python2/3 debacle and while that has subsided, I don't want to run Python 2.7 anywhere. So Bullseye it is for me!
I have just finished an ethercat mill project which is still running on Axis. Being able to install both Linuxcnc and ethercat master from repos was quite exciting for me becasue the existing linuxcnc ethercat master install uses an old repo and did not like Bullseye which I needed for driver support. Fortunately Grotius made a .deb for me. The IgH etherlabmaster repo moved to gitlab but there is no need to build it becasue they have unofficial repos for all OS flavours and versions, not just Debian.
I found an air plasma cutter last night that has options for both RS485 and Canbus control. I'm wondering if this could be built into an ethercat machine...
I have a plasma controller to build for a guy and it will be on QTplasmac as its more mature and has a bigger user base.
As I said before, we are only just scratching the surface with plasma and getting QTP out of master into a release version would propel it forward even further..
- samforsey12345
- Thank you received: 12
As someone who is not conversant in linuxCNC, I would love a stripped back, stable QTplasmaC, integrated into linuxCNC basic install, which, provided an appropriate config and hardware is coupled with it, it would just do the basics. I think that is the point Rod is trying to make.
Just about pulling my hair out at this point. I am three full days in trying to get up to date. I tried going back to the master branch, but for some reason the networking manager failed to work properly, making it impossible to connect to the mesa. I spent about 4 hrs trying to connect to the mesa and failed to get anywhere from manually configuring the network file.
So i am back on debian bullseye. I have tried a combination of the link you sent and the commands you sent, but the best i can get is shown below from the terminal;
Cd ~
mkdir /dev
cd /dev
git clone github.com/LinuxCNC/linuxcnc.git
cd /linuxcnc/debian
./configure uspace no-docs
cd ..
sudo apt install debhelper-compat dh-python autoconf gettext intltool libboost-python-dev libgl1-mesa-dev libglu1-mesa-dev libgtk2.0-dev libmodbus-dev libeditreadline-dev libusb-1.0-0-dev libxmu-dev python3-dev tcl8.6-dev tk8.6-dev yapps2
dpkg-buildpackage -b -uc
cd ..
sudo dpkg -i linuxcnc-uspace_ (tab)
bash: Cd: command not found
mkdir: cannot create directory ‘/dev’: File exists
fatal: could not create work tree dir 'linuxcnc': Permission denied
bash: cd: /linuxcnc/debian: No such file or directory
bash: ./configure: No such file or directory
dpkg-buildpackage: error: cannot open file debian/changelog: No such file or directory
bash: syntax error near unexpected token `('
Where do i go from here? Any idea when the debian repositories will be updated to the latest linuxCNC? I may have to wait for that to happen.
Thank you,
Sam
- phillc54
That is unknown at this stage.Any idea when the debian repositories will be updated to the latest linuxCNC?
If you need to be on Debian 11 or later then the options are:I may have to wait for that to happen.
- Wait.
- Build your own packages.
- Build a run in place install.
linuxcnc.org/docs/html/code/building-linuxcnc.html
Looking back at your first post:
If the actual feed rate does not reach the materials cut feed rate then the THC will not activate.
VAD Threshold is the deactivate threshold. When the actual feed rate falls below this percentage of the materials cut feed rate then the THC will deactivate, it will not reactivate until the actual feed rate reaches the materials cut feed rate again.
Cd ~cd ~I also got one command wrong
mkdir /devmkdir devThe idea is that all of your source code and compiled deb files should end up in your
/home/<your_user>/devPlease Log in or Create an account to join the conversation.
