Dc servo motor control
4 years 6 months ago #240467 by Joeymcc
Replied by Joeymcc on topic Dc servo motor control
Yes it is a 7i92, I could do that with a male-male adaptor, both have female plugs.
When installing the old esab cable for the -10+10V analogue signal I have noticed 2 things:
1. I Had pins the wrong way around. I had signal ground and the -+10v Incorrect!!
2. On the esab wiring the 0v signal pins and the shield are connected, , this is not what I would have expected, I thought that the shield would have went to ground bar and signal ground would be separate. Is it best to connect the signal ground along with the shield?
4 years 6 months ago #240521 by Joeymcc
 Tommy told me so image missing /media/kunena/emoticons/laughing.png
  3mm walls and 8mm floor.
  some wiring done, metal cable ties would be better, tomorrow I will get a few enclosures, one to mount THcad on side of plasma unit and another for mounting Z motor drive and PSU.
4 years 6 months ago #240524 by tommylight
Replied by tommylight on topic Dc servo motor control
Much better! :)
As for the analog signals being tied to ground, i am sure i separated them, but i am also sure i did not mention that to anyone i helped with the retrofit, so it should work both ways, granted you have good grounding in the shop.
The following user(s) said Thank You: Joeymcc
4 years 6 months ago #240556 by Joeymcc
Tommy, my next decision, IHS. I had planned to use ohmic so I removed the esab sensor (2 prox sensors on a air cyclinder). But with the problem earlier Im not sure what to do, you advise to setup first without ohmic, what method should I use? Im used to ohmic on my smaller machine. So far I can think of:
1.  Refit the proximity sensor and air piston setup, however sometimes this was troublesome dependant on the geometry of small parts which were already missing  from the cut sheet.
2. Fit a float switch, the magnetic holder is not strong enough and the torch is knocked off before the z axis carriage lifts, however perhaps it is best to modify this as would be reliable.
3. Fit relay ohmic, I could disconnect the ohmic probe from the circuit during cutting with perhaps 2 relays during cutting. Would it be best to use spdt relay with the resting postion pin to ground?
4. Same as 3 but use thcad plate sensing.
What method is most sucessfull for this type of machine? This machine will not be used for less than 5mm sheet, mostly 8-25mm plates
4 years 6 months ago #240568 by tommylight
4 years 6 months ago #240623 by phillc54
Replied by phillc54 on topic Dc servo motor control
I agree with Tommy, #2 for the materials that you are cutting.
If you did go with #1, QtPlasmaC can do offset probing so that the proximity sensor would probe at the actual pierce coordinates.
If you did go with #3, use a solid state relay, not a mechnical relay.
Time to create page: 0.103 seconds
