Dc servo motor control
4 years 5 months ago #241889 by andypugh
Replied by andypugh on topic Dc servo motor control
That would totally eliminate the issue because if the drive was not "armed" for motion, the encoder becomes the master of motion.
I think that is how it works already....
4 years 4 months ago #244635 by Joeymcc
Replied by Joeymcc on topic Dc servo motor control
Sorry for late reply and thanks. Guys I opened up the min error a little and it has been working perfectly! I feared tolerance would be lost but no problems. Very happy with the Linuxcnc and QTplasmac. It has been worth the extra effort over mach4. When I say extra effort a lot of the trouble for me was just getting used to the linux operating system. I'm suprised how well the height control operates without the need to mess around much with parameters. The float switch has been a good, simple solution (thanks Tommy!) I have been thinking of adding a plate marker of some kind, any ideas whats nice? A camera may be useful for the zero setting due to table width.
The following user(s) said Thank You: tommylight, Clive S
4 years 3 months ago #247177 by Joeymcc
One of the first jobs, very happy. Done some 25mm plate also, performed very well.
4 years 3 months ago #247187 by tommylight
Replied by tommylight on topic Dc servo motor control
Is that the door to X men mansion?
Very nice, indeed.
The following user(s) said Thank You: Joeymcc
4 years 3 months ago #247188 by tommylight
Sorry, forgot about this, here is a nice way of doing markings on the cheap:
And a camera in a plasma environment will not last long, or if isolated properly needs constant cleaning.
Use a small cross laser, cheap and effective.
The following user(s) said Thank You: wasausky, Joeymcc
3 years 10 months ago #259998 by Joeymcc
Tommy, have you found any replacement for the elmo 5/200 dc drives in the esabs?
There is a problem in one of my drives and is causes the fuse for the dc motor supply to blow up at the panel. On inspection there was a blown cap. I replaced all 3 caps but no joy.
On the plus side this is the first problem with the machine since proper completion of the retrofit. It has been brilliant!
Time to create page: 0.076 seconds
