Plasma table + 4th axis
4 years 1 month ago - 4 years 1 month ago #252086 by chrisfischer
Thanks for the tip tommy.
I made an attempt at making commodity carbon tubes into linear rails lasts night. In the end, it was more trouble than its worth.
The tubes i bought were 1.5mm wall 25mm od tubes off amazon. My hope was to bairly scratch the surface to true in any change in diameter so I could slide an igus bearing on it smoothly. I already purchased 25mm igus bearings and they slid with slight changes in friction along the length.
I figured since they are made on a mandrel the id would be concentric but it was pretty out - like .4mm. This meant that I would have to drop the tube down to the next igus bearing size of 24mm. Of course that meant I could grind off a good amount of carbon. The grinder handled this really well. With coolant the wheel didnt load up at all.
Unfortunately the layers under the top are all pulltruded layers rather than a weave. I should have guessed this would be the case. Since there was only pulltruded fibers they were fraying in places rendering this tube useless.
The way to do this right is lay up your own tube with plenty of carbon past where you will grind it back to - all with a weave fabric. This doesn't sound appealing to me so Im changing the z bearings to linear rails.
Last edit: 4 years 1 month ago by chrisfischer.
The following user(s) said Thank You: tommylight, CarterKraft
4 years 3 weeks ago #253610 by CarterKraft
Replied by CarterKraft on topic Plasma table + 4th axis
This is going to be fun to watch. You seem capable of doing some really high quality work.
4 years 1 week ago - 4 years 1 week ago #254555 by razplaz
Replied by razplaz on topic Plasma table + 4th axis
I do, but not always. When using the machine every day i fill the table above the material about 1-3 cm, it is a nice showcase, less metal dust and less ultraviolet radiation. Does not last long though as it evaporates quickly if used all day in about two days it gets under the material level.
Tommy,
Do you have any issues with excessive dross, since the sheets are underwater?
I watched a video with Jim Colt who said cut quality can be better if the water level is slightly below the bottom of sheet.
I was also wondering if the water level affects the THC readings in your experience?
Thanks!
Last edit: 4 years 1 week ago by razplaz.
4 years 1 week ago #254562 by tommylight
Replied by tommylight on topic Plasma table + 4th axis
No, and the dross that gets left is easier to remove when cut with water touching the plate or under water, it cools down much faster so has no time to stick to the rest of material.
In general, no amount of videos will help with cut quality, been there done that, the only thing that really helps is testing and more testing and writing the results.
Get some scrap sheets, set the plasma to say 50A, set the feed rate to 1500mm/m for say 3mm thick plate, check the air is sufficient and do 500mm cuts in a straight line, then do 1600, 1700, etc.
Look under it, get a small hammer and smack the dross see where there is the least dross and comes off easiest, write those settings.
Never ever change 2 or 3 parameters at the same time, that always leads to bigger mess than stared with! :)
The following user(s) said Thank You: razplaz
4 years 1 week ago #254569 by tommylight
Oooops, forgot this:
Not in any noticeable way or form. The current is way to big for the minuscule amount of current that passes through water to cause issues.
4 years 1 week ago #254741 by andypugh
Replied by andypugh on topic Plasma table + 4th axis
Why not plumb a float-valve to the table? (And an overflow pipe in case that fails)
Time to create page: 0.379 seconds
