Plasma table + 4th axis
4 years 1 week ago #254744 by tommylight
Replied by tommylight on topic Plasma table + 4th axis
Does not last long though as it evaporates quickly if used all day in about two days it gets under the material level.
Why not plumb a float-valve to the table? (And an overflow pipe in case that fails)
I like to suffer! :)
That is easy to add, but never though of it, thank you.
3 years 9 months ago #263474 by Dah-Lih Llama
This is exactly what I want to build. I was looking at just buying a 3 axis table, but then I saw a laser machine that had the 4th axis on the side like this. I've got a healthy budget as this isn't for hobby use, but I'm not sure I have the time. I know whatever time I think it's going to take, I might as well multiply by 10.
So, ever make it anywhere past design stage?
3 years 8 months ago #264002 by chrisfischer
It sure is easy to put off posts!
I've got the gantry pretty well designed and started 3d printing parts for a mock fit.
3 years 8 months ago #264003 by chrisfischer
The gantry coming together with 3d prints.
I over designed and over engineered this in the name of training - and fun.
Stiffness is a nice thing to run fea on since its all relative so you dont have to be nervous of the results.
After some crazy lightweighting I got to machining all these pockets. This was another part of the learning curve. I payed attention to my programs, tool usage, and machine time. Trying to think more about the job shop rather than a person having fun without regard to cost.
3 years 8 months ago #264005 by chrisfischer
These are some of the coolest looking parts I've ever machined. After all the work with lightweighting the 4 main parts of the x/z stage I was able to reduce the weight to 49 percent.
3 years 8 months ago - 3 years 8 months ago #264006 by chrisfischer
I am also switching from rhino over to the dark side (fusion 360) for their far superior cam package. Very pleased with all the features I keep learning about.
Last edit: 3 years 8 months ago by chrisfischer.
Time to create page: 0.139 seconds
