- Thank you received: 10
No success obtaining value of encoder from THCAD-10
- santy
3 years 11 months ago #257567
by santy
Replied by santy on topic No success obtaining value of encoder from THCAD-10
i believe i might be missing the frequencies and some other values which are asked by a prompt in QtPlasmaC. But im using PlasmaC only, which only asks for the voltage encoder port.
i wouldn't know how to change these values in the hal file directly, so i am trying to switch to qtplasmac (which seems to have an even better user interface)
Tried running " qtplasmac-plasmac2qt " in a terminal to switch from plasmac to qtplasmac but the command didnt work.
- snowgoer540
- Thank you received: 907
3 years 11 months ago #257570
by snowgoer540
Replied by snowgoer540 on topic No success obtaining value of encoder from THCAD-10
Seems like you’re just starting out, so I recommend using pncconf and choosing qtplasmac as the screen which will do everything for you, including the calculations for the thcad.
- santy
3 years 11 months ago #257572
by santy
i had no idea pncconf had a pre-made config for qtplasmac. thank you, will try now.
yes I'm starting out on linuxcnc! i have a bunch of old non-functional industrial machines; mills, plasma oxy, lathe, and a bunch of others my dad left me a few years back, and have decided to retrofit most of them. the first one is plasma and oxy and the next will be an ATC mill retrofit.
- santy
3 years 11 months ago #257576
by santy
guess i'll have to update from linuxcnc 2.8 to 2.9.
- santy
3 years 11 months ago #257753
by santy
Do you mean this ?
Should i try to paste this "somewhere" along the hal file in order for it to work?
loadrt encoder num_chan=1
setp encoder.0.counter−mode 1
setp encoder.0.position−scale -1
addf encoder.update-counters base-thread
addf encoder.capture-position servo-thread
net arc-voltage-raw parport.1.pin-04-in encoder.0.phase-A
If you look at the encoder velocity in halshow and its not bouncing arround near 3800 (eg its static), there are some settings missing in your hal file. I think they are covered in the Plasmac docs.
- snowgoer540
3 years 11 months ago #257756
by snowgoer540
That is the example for a parallel port, I thought you stated you had a 7i96s.
I thought you were moving over to QtPlasmac? Yes, that does require you to be on 2.9, but you also get to use the pncconf that has qtplasmac as a screen by default. That will do all of this for you.
I made a guide that in addition to installing MX Linux, may help you get QtPlasmaC going. You mentioned you are pretty new to linux, so following the guide as a whole may make the transition a bit easier for you.
forum.linuxcnc.org/9-installing-linuxcnc...red-toward-new-users
Do you mean this ?
Should i try to paste this "somewhere" along the hal file in order for it to work?Code:loadrt encoder num_chan=1 setp encoder.0.counter−mode 1 setp encoder.0.position−scale -1 addf encoder.update-counters base-thread addf encoder.capture-position servo-thread net arc-voltage-raw parport.1.pin-04-in encoder.0.phase-A
Time to create page: 0.138 seconds
