7i96 with THCAD-2 setup on Everlast 82i
- kello711
10 May 2025 16:44 - 10 May 2025 17:40 #328160
by kello711
7i96 with THCAD-2 setup on Everlast 82i was created by kello711
Hello all. I'm having some issues with getting my THCAD-2 setup with the Everlast 82i. I'm pretty sure I have all the settings correct. I opened the Everlast and set the jumper to the 16:1 divider ratio (as suggested). On the THCAD-2 I used the 10:1 (W1 Up setting) and left the card divider on 1. I used pnfconf to configure the THCAD and got the following settings:
Arc Voltage Offset = 100200.0
Arc Voltage Scale = 0.000199
In Qtplasmac I'm getting a -20 voltage reading instead of 0 V. I set the machine to run a small bit of G code and measured the voltage coming off pins 4,6 from the Everlast. This is consistently getting ~4.5V when running at 40A cut power. When I connected a 9V battery to the I+ and I- directly on the THCAD-2 the power in HALSHOW is jumping all over the place. However, when I connect the wires from the plasma back to the THCAD, I get no indication of any voltage when running a job.
Any help you can provide would be greatly appreciated.
Last edit: 10 May 2025 17:40 by kello711.
- Thank you received: 4151
10 May 2025 18:35 #328165
Replied by rodw on topic 7i96 with THCAD-2 setup on Everlast 82i
Set the divider ratio on the board to 1/32 (Needed for Linuxcnc)
Use the thcad calculator here jscalc.io/calc/NTr5QDX6WgMThBVb
Use the plasma divider ratio of 24:1 (an Everlast Quirk) in linuxcnc
Leave the Everlast divider board as 16:1
If you are getting negative values you have bigger problems than config issues.
Check your encoder velocity in halshow, it should be showing around the 0 volt sticker frequency ( / 32)
With the 9 volt battery, it should show near full scale, Calculate what it should be by hand
The following user(s) said Thank You: kello711
- Thank you received: 5331
10 May 2025 19:21 #328172
Replied by PCW on topic 7i96 with THCAD-2 setup on Everlast 82i
THCAD/THCAD2 frequency divide by 1 will not work reliably
with default 7I96 encoder settings, so as rodw suggests:
use 1/32.
use 1/32.
The following user(s) said Thank You: rodw, kello711
- kello711
13 May 2025 15:24 #328392
by kello711
Replied by kello711 on topic 7i96 with THCAD-2 setup on Everlast 82i
Looks like the /32 setting was the ticket. Between that and making the offset/scale changes, it appears my voltage readings are in order. Next step is getting the voltage/height adjustments in setup.
Do you happen to have any material libraries for the Everlast 82i? IIRC, you were using that before. I haven't been able to find anything reliable online yet.
Time to create page: 0.123 seconds
