Thinking of moving my Plasma from Masso to LinuxCNC
28 Feb 2026 00:38 #343628 by gomond
Hi all my name is Greg I have been watching this forum for years and this is my first post.
I built a CNC plasma 2 years ago and I used a Masso CNC v3 with their DTHC, as I couldn't get the after market ones to play nicely with it.
I have had nothing but trouble with this machine, yet I have a CNC router and a CNC mill using Masso's and they work great.
The Plasma on Masso is just immature and failure prone. I have built many Plasma cutters for friends using MyPlasm and it is about 1/8 the price and flawless .
I have been watching Rods videos and am very impressed with his results. So I bought a Mesa 7i96 card but I am now retired and a pensioner so I don't have the income like when I was working hence my question , can I implement THC and OHMIC on the existing board or use the ProKeys Fibre linked THC that I have from the Masso experiments and the CNC4PC Ohmic also left over?
Thanks Heaps for any advice
Cheers Greg.
Arthurs Creek, Vic.
28 Feb 2026 02:17 #343630 by rodw
Damn, I thought I may have had a thcad here in Brisbane but I looked and I don't.
If you have a THC that generates an up/down signal, you could use it if you set the right mode in qtplasmac. Looks like the pokeys may do that.
Totally untested but I do think my hypersensing component would probably be able to be modified to do ohmic and voltage sensing it does sense arc voltage but the scale is only 24.5 volts so it just stays on. with better scaling you probably could do both.
The following user(s) said Thank You: gomond
11 May 2026 12:22 #346328 by arcsynapse89
Replied by arcsynapse89 on topic Thinking of moving my Plasma from Masso to LinuxCNC
Hi Greg,
I have a spare THCAD board that was donated to me by a fellow Linuxcnc forum member that I can send to you if you still need it. Its out in my storage unit in Dubbo so it might be a while before I can send it to you.
You can contact me on my email This email address is being protected from spambots. You need JavaScript enabled to view it.
10 Aug 2026 02:37 #348623 by gomond
Thanks Heaps Stefan and Rod I just received the THCads and am about to draw up my Transition drawings from masso to linuxcnc.
Have either of you used Qelectrotech for drawing before as I am about to give it a go. Supposedly there are libraries for Mesa boards available.
10 Aug 2026 11:33 - 10 Aug 2026 11:38 #348628 by arcsynapse89
No worries Greg. I have not used Qelectrotech before but for my wiring diagrams I use old school 2d AutoCAD. I looked at Qelectrotech and it looks good. I have used TinkerCAD and CircuitLab for some university courses I have been studying and they work ok, but I am sure you could do some good drawings with Qelectrotech.
Last edit: 10 Aug 2026 11:38 by arcsynapse89.
11 Aug 2026 13:00 #348649 by rodw
Sean Drummond did a really nice diagram of a 7i96s which you can grab over at plasmaspider plasmaspider.com/viewtopic.php?p=231679#p231679
If you want a diagram you can't go better. I usually just create a table of all the pins and where that go. Its better to do it in a word document rather than a spreadsheet so you can add more freeform text/
13 Sep 2026 23:06 #349620 by gomond
Thanks Rod
Its a ripper, just what I was after,
14 Sep 2026 01:42 #349622 by FabLabRacing
Replied by FabLabRacing on topic Thinking of moving my Plasma from Masso to LinuxCNC
I just did the same thing, Please feel free to reach out if you need any help. I feel like I learned a fair bit along the way...
