In what way do you see 2x50k as a better way than 1x100k?
You get voltages in the 50-60V range to THCAD.
With one 100k, and recognize that ground is really close to ground on the 5V rail,
you only get a few volts in after the voltage divider.
I thought about that on my card.
Only what is in red has 100V (well, -100V) and thereabout, the rest is 5V max.
I made some distance between torch voltage and copper as you can see in the read.
I always excuse myself by saying I am not an electric engineer, so I can be wrong.
Regarding filter, I have a digital lowpass filter with 10 Hz pole frequency in the controller. No hardware filter.
Linuxcnc has a "lowpass" hal filter component so it can be done there also.
I used the Herocut equivalent to the Lotos. Worked fine.I live in a place where we only can have 16A, absolutely max 20A, 230V at home.
I couldn't use all the 55A, the fuse blew all the time. I replaced it with a Herocut HC8000, three phase 400V 16A. I can now max out
the plasma cutter. But the compressor need to run off the petrol generator, it's too much with that one on one phase too.
