Using Plasmac to draw with a marker
- snowgoer540
- Thank you received: 907
09 Feb 2020 20:31 #156903
by snowgoer540
Using Plasmac to draw with a marker was created by snowgoer540
Good afternoon.
I have a client who wanted to see what a sign would look like before she had me cut it. I figured the easiest way to do this was with a spring loaded marker holder, which i designed and 3D printed. I set out in Fusion and created a file with the engrave command which traced the lines perfectly. I opened the file and removed all of the erroneous M commands, as well as some other stuff I knew Plasmac wouldnt like.
The only problem is that Plasmac has commented out all of the Z moves. I know it does that because M3 triggers a routine to handle all of the touch offs. My question is, is there a way to enable them again, so that I can use the trace command to use a marker and not have a ton of erroneous lines? I can see myself using this new marker tool a lot, as it would be handy not only with showing clients, but also plate layout, marking hole patterns, etc.
I am trying to avoid having an entire LinuxCNC install dedicated to a marker.
Any thoughts?
-Greg
Any thoughts?
-Greg
- Thank you received: 7501
09 Feb 2020 21:20 #156909
Replied by tommylight on topic Using Plasmac to draw with a marker
Create a simple config for your machine, well you should already have that so you can start that config when you need the pen. No need to install Linux again, Linuxcnc can have as much configs as you can create .
- phillc54
- Thank you received: 2100
09 Feb 2020 21:40 #156910
by phillc54
Replied by phillc54 on topic Using Plasmac to draw with a marker
If you comment out the following section in the ini file then PlasmaC won't make any changes to the loaded program.
Although if you are going to be making Z moves then I think it would be better to follow Toms suggestion.
# this section required as is for removing z axis moves from the loaded gcode file
# this is optional and if used then plasmac_gcode.py needs to be set as executable
[FILTER]
PROGRAM_EXTENSION = .ngc remove z axis stuff
ngc = ./plasmac_gcode.py
- snowgoer540
09 Feb 2020 23:48 #156919
by snowgoer540
Replied by snowgoer540 on topic Using Plasmac to draw with a marker
Ah, I guess that’s what I meant by more linuxcnc installs. It’s not a huge deal, easy enough. New config “marker” it is. Thanks for the replies!
26 Feb 2020 13:15 - 26 Feb 2020 13:18 #158532
Maybe Plasmac could use block delete rather than comment for Z moves?
(I know that LinuxCNC supports block-delete, and there are buttons in the GUIs, but I have not found any docs on it in a manual newer than 2.3)
Found it: linuxcnc.org/docs/2.7/html/gcode/machini...:block-delete-switch
Replied by andypugh on topic Using Plasmac to draw with a marker
Last edit: 26 Feb 2020 13:18 by andypugh.
- Thank you received: 4154
26 Feb 2020 20:38 #158572
It would be helpful if the docs outlined how to turn the switch on and off. Its in halui (together with some status pins to tell the states of the switch
Replied by rodw on topic Using Plasmac to draw with a marker
halui.program.block−delete.on bit in
pin for requesting that block delete is onPlease Log in or Create an account to join the conversation.
- Thank you received: 2181
26 Feb 2020 21:27 #158573
Replied by cmorley on topic Using Plasmac to draw with a marker
halui is only one way. Most guis have a button for it.
In the docs the word 'switch' was probably a bad choice of words - it's in the programmers sense; an on/off choice.
block delete must be set before the program is run in linuxcnc for some reason.
Chris
Chris
26 Feb 2020 22:16 #158575
What about
Axis has a button for ignoring lines starting with
That can be used for many things, one of them was in axis splash screen where it would hide or show a part under the EMC2 logo, i think it was "powered by linux" or.....
- phillc54
26 Feb 2020 22:35 #158579
by phillc54
Another option may be to set you marker up like a scribe.
linuxcnc.org/docs/devel/html/plasma/plas...er-guide.html#scribe
26 Feb 2020 23:40 #158584
That is block delete
What about
Time to create page: 0.098 seconds
