Watchdog has bit!
- little_sparky
- Thank you received: 17
13 Jun 2020 04:28 #171364
by little_sparky
Watchdog has bit! was created by little_sparky
Hi All,
not sure if this is a Linuxcnc based error or PlasmaC but I had this watchdog has bit error come up before when I was using my machine as a router and now that I am finally running PlasmaC this error has come up again. Im not sure if its anything to do with plasmaC or just a coincidence but does anyone know how i can fix it?
Could it be an issue with my mesa card or is it definitely my computer?
Thanks in Advance
Thanks in Advance
- Thank you received: 5335
13 Jun 2020 04:56 #171365
Replied by PCW on topic Watchdog has bit!
That is usually an issue with latency on the host but a few other possibilities are
1. Watchdog timeout too short
2. Some other cause of communication dropouts
3. Host PC has Intel Ethernet chip but IRQ coalescing left on
- little_sparky
13 Jun 2020 04:59 #171366
by little_sparky
Replied by little_sparky on topic Watchdog has bit!
Okay thank you I’ll look into it.
Do I change watchdog timeout in Hal? And what should it be?
Also could it have anything to do with isolcpus?
13 Jun 2020 05:07 - 13 Jun 2020 05:10 #171368
What is your host CPU?
isolcpus sometime helps. but not always
Normally the watchdog time is set for 5 to 50 ms if you have a 1 ms servo thread
Increasing the timeout value may avoid the watchdog biting but
just masks the real problem: You have a real time error.
Last edit: 13 Jun 2020 05:10 by PCW.
- little_sparky
13 Jun 2020 05:15 #171370
by little_sparky
Dell Optiplex 990 SFF Intel Core i5 2400/3.1GHz, 4GB ram 120GB SSD WIN10
13 Jun 2020 05:22 #171371
OK that has a Intel MAC, have you turned off IRQ coalescing?
- little_sparky
13 Jun 2020 06:18 #171374
by little_sparky
I checked my /etc/network/interfaces file and it appears i have IRQ coalescing turned off.
I also looked into my interfaces.d/setup file and it looks pretty blank, should this have coalescing in it too?
I have also changed my isolcupus to isolcupus=3, i am running latency to see if this changes anything.
In this same file it has cstate=1, should this equal 0?
Files are attached.
interfaces
grub
Files are attached.
interfaces
grub
- Mike_Eitel
- Thank you received: 183
13 Jun 2020 11:11 #171404
by Mike_Eitel
Replied by Mike_Eitel on topic Watchdog has bit!
You must not have eth0 and eth1 the same adress
- little_sparky
13 Jun 2020 11:13 #171405
by little_sparky
Which one should I use? Or how do I know what one to use?
- Mike_Eitel
13 Jun 2020 11:41 - 13 Jun 2020 11:41 #171408
by Mike_Eitel
As pcw proposed you already switched of irq on eth1 so stick to that.
Just for completeness give it a mask of 255.255.255.0.
And make a direkt cable from that port to the mesa card. Nothing in between.
And i would reconfigure eth0 to dhcp and connect to the rest of your network.
Mike
Mike
Last edit: 13 Jun 2020 11:41 by Mike_Eitel.
Time to create page: 0.280 seconds
