7I96 Plasmac THAC / encoder config question
27 Jun 2020 21:53 #172919 by calvin.d
I am setting up a 7I96 to use with a small plasma cutter. I am trying to confirm the dual THAC setup. Can I use the stock bit file for the 7I96 or do I need one with 2 encoders instead ?
the stock bit file for a 7I96 looks like it has a single quad encoder setup
TB1
pin 27 Quad-A
pin 28 Quad-B
pin 29 Quad-IDX
The Plasmac instructions is based on the 7I76E for the connections
Assuming it is connected to a 7i76e, connect the output to the spindle encoder input:
THCAD +5v to TB3 Pin 6 (+5 VP)
THCAD -5v to TB3 Pin 1 (GND)
THCAD FOUT+ to TB3 Pin 7 (ENC A+)
THCAD FOUT- to TB3 Pin 8 (ENC A-)
For the second encoder it needs a separate bit file that adds another encoder input to read
Thank you for the help
Calvin
27 Jun 2020 21:56 #172921 by snowgoer540
Replied by snowgoer540 on topic 7I96 Plasmac THAC / encoder config question
TB1
pin 27 Quad-A
pin 28 Quad-B
pin 29 Quad-IDX
Calvin
There is a zip file of firmwares on the Mesa site for the 7i96 card. There’s a 7i96dpl.bit (or something very similar, doing this from memory), use the mesaflash guide in the 7i96 manual to flash the firmware on the card. It will give you three Quad-A encoders, which you will use two of them. Then you’ll use the .00 velocity for THC and .01 velocity for ohmic.
Hopefully that makes sense...
27 Jun 2020 21:59 #172922 by calvin.d
Replied by calvin.d on topic 7I96 Plasmac THAC / encoder config question
yes it does, I was hoping there as a pre made bit file for this
ill give it a try now
Thank you
27 Jun 2020 22:00 #172923 by snowgoer540
Missed the connections question, just follow the pin out guide on the 7i96 manual, it’s still ENCA+ and ENCA- for the thc, then you’ll use the ENCB+ and ENCB- for the ohmic, but the firmware will identify it as two QUAD-A’s
27 Jun 2020 22:29 #172925 by calvin.d
Looks like that was exactly what I needed
for anyone in a similar situation
1. get the support software for the 7i96 from the mesa site
2. connect to the board via mesa flash tool
"mesaflash --device 7i96 --addr 10.10.10.10 --reashmid"
will give you the current pinout based on the bit file loaded
3. decompress and find the 7i96dpl.bit file in the support software
4.flash the board
"mesaflash --device 7i96 --addr 10.10.10.10 --write 7i96dpl.bit"
5. power cycle or use mesaflash to reload
6. confirm the new bit file was loaded and the pinout changed
This now gives me
TB1
Pin 7 Quad-A
Pin 8 Quad-A
Pin 9 Quad-A
So I now have 3 A channels on 3 separate encoders, these are single ended right so now I am just running
THCAD FOUT+ (THCAD#1) ---> pin 27 Quad-A
THCAD FOUT+ (THCAD#2) ---> pin 28 Quad-A
and I am not connecting THCAD FOUT- to anything right ?
Is it worth while ti look into a bit file that has and A and -A pair for better signal protection ?
C
27 Jun 2020 22:36 - 27 Jun 2020 22:36 #172927 by calvin.d
From the manual
TB2
7 ENCA+
8 ENCA-
10 ENCB+
11 ENCB-
is now really
TB2
Pin 7 ENC0A+
Pin 8 ENC0A-
Pin 10 ENC1A+
Pin 11 ENC1A-
so that maps to
THCAD FOUT+ (THCAD#1) ---> Pin 7 ENC0A+
THCAD FOUT- (THCAD#1) ---> Pin 8 ENC0A-
THCAD FOUT+ (THCAD#2) ---> Pin 10 ENC1A+
THCAD FOUT- (THCAD#2) ---> Pin 11 ENC1A-
C
Last edit: 27 Jun 2020 22:36 by calvin.d.
28 Jun 2020 00:31 #172932 by snowgoer540
Yep! Looks like you got it figured out! Thanks for the extra intel for those who come looking.
28 Jun 2020 00:35 #172933 by calvin.d
ok next problem
starting linuxcnc
error
setp requires 2 arguments, 1 given
for this line
"step hm2_[HOSTMOT2](Board).0.encoder.00.velocity
the initial config was made with the 7i96 config tool, I think I am going to convert it and hardcode all off the variables our of the config lines
still trying to figure out why that encoder line is not reading correctly
C
28 Jun 2020 00:40 #172934 by snowgoer540
ok next problem
starting linuxcnc
error
for this line
C
There’s an example in the plasmac user guide in section 27, but I think the (board) just needs to be changed to 7i96.
28 Jun 2020 00:40 #172935 by phillc54
Replied by phillc54 on topic 7I96 Plasmac THAC / encoder config question
You may be better off using Pncconf and unchecking all the extra options then you don't end up with a lot of unnecessary lines. The encoder velocity line for instance is not need in the hal file but is set later by the Configurator.
Time to create page: 0.604 seconds
