THCAD-300 Jumper
6 years 3 months ago #174241 by KaleD
THCAD-300 Jumper was created by KaleD
I'm setting up a THCAD with raw arc voltage. What is the best jumper setting to use? My Hypertherm 600 is a pretty old machine and has no divided voltage. As far as the jumpers go I don't quite understand the rationale behind choosing what to use. I've read the Plasmac user guide and a few posts but I haven't quite figured it out. any links or explanations would be appreciated.
6 years 3 months ago #174256 by tommylight
Replied by tommylight on topic THCAD-300 Jumper
Kale, more info, please.
To what you are connecting the THCAD ?
If to a Mesa card, then 1/32 is the best option regarding noise immunity and resolution.
If to a parallel port, that will greatly depend on how good the latency of that PC is.
Also, be very careful where you wire the THCAD inside the plasma source, there is only one place inside it that the THCAD can be safely wired, otherwise it is very likely to mess up the card.
Pictures of the insides of the plasma source would help to pinpoint the location.
Or maybe your plasma has an output for THC with full voltage scale (no divider), so that is easy.
6 years 3 months ago #174265 by KaleD
Replied by KaleD on topic THCAD-300 Jumper
I'm using a Mesa 7i96. Here are some pictures inside the plasma:
Above,
The left screw terminal is the wire for the ground clamp. The middle with the red wire is labeled 500v. The white wires I can't say for certain what they are.
There is no plug for raw voltage.
6 years 3 months ago #174266 by KaleD
The plug with the purple wires are for a relay to fire the torch. The blue wires are currently irrelevant.
6 years 3 months ago #174272 by KaleD
I found the Schematic. This clears up what the wires from the screw terminal are. I still need to figure out whether the THCAD should be hooked to the electrode or ground.
6 years 3 months ago #174276 by tommylight
Kale Dobrohoczki wrote: The left screw terminal is the wire for the ground clamp. The middle with the red wire is labeled 500v.
I really hope Hypertherm did not put that terminal there, that is a 16A/500V terminal, hence that is not a label for anything except the terminal block. The left wires (you said go to the clamp) should be yanked from that terminal strip and put on a 60A to 100A terminal.
The SanRex part is the rectifier for 600V/60A, so you can attach the THCAD inputs to the + and - terminals on that rectifier, not on the ~ terminals. Use proper plugs for that and tighten the screws properly.
Time to create page: 0.196 seconds
