THC enabling. Are we doing it wrong?
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
25 Aug 2020 11:04 - 25 Aug 2020 11:05 #179343 by rodw
www.plasmaspider.com/viewtopic.php?f=3&t=13359#p78176
Jim Colt says:
6. Once the machine achieves the programmed x - y cut speed, the height control starts monitoring the DC arc voltage (as measured between the plasma torch negative electrode and the positive work cable) and compares the actual arc voltage to a preset arc voltage (as suggested by the plasma torch manufacturer for the material and thickness being cut), then the height control adjusts the z axis so that actual arc voltage and preset arc voltage are essentially the same. If actual voltage is too low...the z axis indexes up until the voltage matches the preset.
Its occurred to me recently that the piercing voltage spike we see is probably heavily influenced by acceleration. So a fast accelerating machine will get to cut speed faster and once it does voltage should stabilise. Here is Jim confirming that.
Where is our test pilot? this would be a perfect opportunity to learn how to use halscope and monitor torch voltage, current velocity and feed rate and see if without a THC torch voltage stabilises when you get to cut velocity. If it does, we could get rid of the THC delay and enable it at cut velocity (or some small delay after that is reached).
The more we simplify operations, the better I think!
Last edit: 25 Aug 2020 11:05 by rodw.
25 Aug 2020 11:10 #179345 by snowgoer540
Replied by snowgoer540 on topic THC enabling. Are we doing it wrong?
Jim Colt says:
Test pilot here... did you think I was going somewhere? :laugh:
To your point, I don't know if I've ever seen a THC delay on another machine before, but that doesn't mean that it wasn't baked into the controller and wasn't user programmable.
Measuring THC delay is on my list of things to do at some point anyhow, as is learning Halscope. The two seem to be hand in hand LOL. This is following me, it will catch up and tackle me shortly, don't worry.
25 Aug 2020 11:11 #179346 by phillc54
Replied by phillc54 on topic THC enabling. Are we doing it wrong?
If that is the case you could get rid of the delay now as it doesn't sample the arc voltage until it has reached 99.9% velocity.
  • rodw
  • Platinum Member
  • Platinum Member
25 Aug 2020 11:16 #179349 by rodw
Replied by rodw on topic THC enabling. Are we doing it wrong?
Exactly my point! But when does it enable the THC?
  • rodw
  • Platinum Member
  • Platinum Member
25 Aug 2020 11:19 #179351 by rodw
I think most THC's will have a delay but Linuxcnc is one of the few that has access to the motion control parameters so we should be able to get smarter...
25 Aug 2020 11:19 - 25 Aug 2020 11:22 #179352 by phillc54
After it has collected the sample and the delay has expired.
Edit: I should add that the sample is taken over six cycles after reaching 99.9%
Last edit: 25 Aug 2020 11:22 by phillc54.
25 Aug 2020 11:34 #179356 by snowgoer540
The thought I would have against removing the delay would be machines with high acceleration will get to the commanded velocity pretty fast. Also, this will vary with material thickness and obviously material feed rates (slower feedrates will get there much faster). At any rate, I wonder if the arc is really stable by the time it reaches 99.9%.
I guess that's what the testing is for, I'm just thinking out loud.
  • rodw
  • Platinum Member
  • Platinum Member
25 Aug 2020 11:57 #179359 by rodw
Its something I never considered in the past when I was doing cut after cut in halscope. (Phill put me out of a job). I have not really done any cutting since upgrading my machine to 5 m/s^2 acceleration (0.5G roughly). I still need to stiffen up the gantry ends desperately but 50+% sales growth has severely cut into my quality plasma time! But that also means I need to cut more parts.
Thats why it needs testing on a few machines.
25 Aug 2020 17:18 #179414 by kramerda
Replied by kramerda on topic THC enabling. Are we doing it wrong?
Following this discussion in the background......what are the units of the velocity and Accel in the ini file for each joint / axis
  • Moderator
  • Moderator
25 Aug 2020 17:22 #179415 by tommylight
Replied by tommylight on topic THC enabling. Are we doing it wrong?
Machine units per second.
So if your machine is in mm, the units in the ini file are in mm/s, but they are in mm/m in the GUI.
Time to create page: 0.116 seconds
