Need help setting up HAL files for MESA THCAD10
- CCharles
10 Apr 2021 15:23 #205529
by CCharles
Need help setting up HAL files for MESA THCAD10 was created by CCharles
Hi everyone,
I built a CNC plasma table a few years ago and it has been working well overall. I finally decided to get the THC up and running. I have been using it without. I have an Everlast 50 with the CNC port that is a few years old. I purchased a Mesa THCAD10 board and believe I have it wired correctly to the Everlast. I am getting a changing voltage to the THCAD10 while cutting. I should add I am using a Gecko G540 and have added a second parallel port. Also using the PLASMAC GUI.
I cannot for the life of me figure out how to get the HAL and INI files setup. I have read every manual and forum post I could find for a few weeks now and I am about ready to just live with the plasma table the way it is without THC.
I have attached the HAL and INI files along with a pic of an error I am getting. If I comment out the "setp encoder.0.counter−mode 1 and
setp encoder.0.position−scale -1" I can get Linuxcnc to load but the THC doesnt work. Shows 0 volts.
Thank you for any help.
- Thank you received: 5328
10 Apr 2021 16:19 - 10 Apr 2021 16:47 #205536
Replied by PCW on topic Need help setting up HAL files for MESA THCAD10
1. The THCAD output frequency will be too high to read with the software encoder
unless you use the /64 or better /128 division setting on the THCAD
2. You have a strange character (wrong dash) in your setp command:
setp encoder.0.counter−mode 1 (Has a UTF-8 minus sign between counter and mode)
should be
setp encoder.0.counter-mode 1 (Has a standard ASCII dash between counter and mode)
This can happen if you use something other than a text editor
to edit the hal/ini files
should be
Last edit: 10 Apr 2021 16:47 by PCW.
- snowgoer540
- Thank you received: 907
10 Apr 2021 16:43 - 10 Apr 2021 19:22 #205538
by snowgoer540
Replied by snowgoer540 on topic Need help setting up HAL files for MESA THCAD10
EDIT: Finally home, realized you are working with a paraport.
In addition to what PCW said, it looks like you commented out the second half of your encoder assignment. Remove the # from this line:
#net plasmac:arc-voltage-in => plasmac.arc-voltage-in
Or you can do it all on one line:
net plasmac:arc-voltage-in encoder.0.velocity => plasmac.arc.voltage-in
Last edit: 10 Apr 2021 19:22 by snowgoer540.
- CCharles
10 Apr 2021 20:40 #205554
by CCharles
Replied by CCharles on topic Need help setting up HAL files for MESA THCAD10
Definitely did not see that. Thank you for pointing that out. I will change that and try it. I am using the program called Brackets that I use to modify my g-code .
- CCharles
10 Apr 2021 20:42 #205555
by CCharles
Does that mean I dont need that line if I am using a paraport? This is where some of my confusion comes from.
10 Apr 2021 20:49 - 10 Apr 2021 20:49 #205556
Brackets seems like a web/html editor, probably not ideal for gcode or programs
(unless it has a ASCII only mode)
Last edit: 10 Apr 2021 20:49 by PCW.
- CCharles
10 Apr 2021 21:04 #205557
by CCharles
Its the recommended program that automatically pops up when using Fusion360 for CAM post processing.
10 Apr 2021 21:20 #205559
Not sure why you would you use a utf-8 editor on program text
- CCharles
10 Apr 2021 21:27 #205562
by CCharles
Idk. but never had a problem with using it for any of my g-code. But I just opened my HAL files in notepad++ with ANSI encoding on. I see what you are saying about those two lines. I have corrected them and will report back. One of the things I am not sure about....Am I correctly telling Linuxcnc to look for the arc.voltage.in at the parallel port 15?
- snowgoer540
10 Apr 2021 21:37 #205568
by snowgoer540
Did you see this post: forum.linuxcnc.org/plasmac/42205-need-he...-mesa-thcad10#205538
Time to create page: 0.175 seconds
