- Thank you received: 486
How to move a QTplasmaC config
- Clive S
- Topic Author
5 years 6 months ago #207561
by Clive S
How to move a QTplasmaC config was created by Clive S
How to move a QTplasmaC working config from a to another PC.
IE. can I just move the config folder over or will there be some sim-link or Python issues ?
5 years 6 months ago #207568
Replied by tommylight on topic How to move a QTplasmaC config
Zip the config folder, save to a USB, copy, unzip, right click on the ini file and choose "open with other application" then type linuxcnc and press enter.
- Clive S
- Topic Author
5 years 6 months ago #207569
by Clive S
As easy as pie !!
I don't think you could do that with PlasmaC because of all the sim-links
Replied by Clive S on topic How to move a QTplasmaC config
tommylight wrote: Zip the config folder, save to a USB, copy, unzip, right click on the ini file and choose "open with other application" then type linuxcnc and press enter.
As easy as pie !!
5 years 6 months ago #207572
It did work for PlasmaC also with zipping the folder, at least it worked on several PC's i used.
Time to create page: 0.094 seconds
