Conversational cut direction
- sm2wmv
- Topic Author
5 years 6 months ago #207950
by sm2wmv
Conversational cut direction was created by sm2wmv
Is there any way to change the cut direction in conversational mode?
For me it currently cuts inner cuts clockwise and the outer cut paths are counter clockwise.
Am I missing something in some other setting?
- phillc54
- Thank you received: 1802
5 years 6 months ago #207951
by phillc54
Replied by phillc54 on topic Conversational cut direction
PlasmaC or QtPlasmaC?
Which shapes?
Which shapes?
- bevins
- Thank you received: 133
5 years 6 months ago #207959
by bevins
Replied by bevins on topic Conversational cut direction
my QTPlasmaC is running in the correct direction on all shapes. Internal and external.
- sm2wmv
- Topic Author
5 years 6 months ago - 5 years 6 months ago #207963
by sm2wmv
Replied by sm2wmv on topic Conversational cut direction
That is QTPlasmaC.
I have tried circles, squares and polygon both inside and outside cut.
Can be seen here,
Have I got some setting wrong? This is my coordinate system (seen from above, the ~ are the waves in the water table :lol: ).
Y+
Y-
X- X+ (homing corner)
Can be seen here,
Y+|~~~~~~~~|
Y-X- X+ (homing corner)
Last edit: 5 years 6 months ago by sm2wmv.
- sm2wmv
- Topic Author
5 years 6 months ago #207964
by sm2wmv
I might be wrong, I need to do more tests tonight and see. I am looking at the cuts I did yesterday and by the looks of it that might be cutting in the right direction. That video is quite early and I might have changed some in the coordinate system after that. I will test this so don't waste any time before I have double checked this.
- bevins
5 years 6 months ago #207968
by bevins
You can see which direction it will cut in the conversational window. look at the arc leadin.
- sm2wmv
- Topic Author
5 years 6 months ago #207979
by sm2wmv
I was totally wrong. I was trying to figure out my bevel issues yesterday and looked at the old video and saw that I was cutting the wrong direction, forgetting that I changed the coordinate system after that which inverted the cuts. Now I checked the parts I cut yesterday and the cut direction was correct. So sorry for my stupidity and ignore this thread
5 years 6 months ago #207990
Replied by tommylight on topic Conversational cut direction
Home should be front left.
Time to create page: 0.060 seconds
