- Thank you received: 4
Varios botones home
- wasausky
- Topic Author
5 years 5 months ago #208025
by wasausky
Varios botones home was created by wasausky
I am working on axis plasmaC.
If I want to cut a plate from a scrap I would only use home at 0,0,0 in the center of the plate.
Now if I have an iron that fits exactly on the waterbed I would use the home switches located at the end of the table, for this the axes would look for these switches.
If he lost home due to movement and bad maneuvering, he would use the single-axis home plate with his switch.
I would like to know how to implement these buttons on axis using those axis pins.
5 years 5 months ago #208427
Replied by rodw on topic Varios botones home
Just do a G54 touchoff on X & Y where you want to start cutting from.
The following user(s) said Thank You: wasausky
5 years 5 months ago #208590
Replied by andypugh on topic Varios botones home
You can use an external button and MDI_COMMAND to issue a G10 command to set the origin.
halui.mdi-command: linuxcnc.org/docs/2.8/html/man/man1/halui.1.html
G10 L20 - linuxcnc.org/docs/2.8/html/gcode/g-code.html#gcode:g10-l20
[HALUI] section in the INI - linuxcnc.org/docs/2.8/html/config/ini-co....html#_halui_section
- snowgoer540
- Thank you received: 907
5 years 5 months ago #208664
by snowgoer540
Replied by snowgoer540 on topic Varios botones home
There are several examples of custom user buttons in the PlasmaC user guide. Touching off X and Y is one of the examples.
linuxcnc.org/docs/devel/html/plasma/plas...#custom-user-buttons
- wasausky
- Topic Author
5 years 5 months ago #208889
by wasausky
Replied by wasausky on topic Varios botones home
thank you all now if I have what I wanted. they really take their work very seriously
Time to create page: 0.055 seconds
