qtplasmac error message
5 years 2 months ago - 5 years 2 months ago #216896 by phillc54
Replied by phillc54 on topic qtplasmac error message
OK, the qtdragon.log was leading me up the wrong path, I see you have that specified in the .ini file.
I set your config up as a sim and could not see the issue.
It would be worth trying it with the "LOG_FILE = qtdragon.log" line commented out.
Failing that it may be worthwhile for you to set the default python on your PC to python3.
linuxconfig.org/how-to-change-from-defau...ion-on-debian-linux/
Then after doing that run the qt install script:
/home/colten/git/linuxcnc/lib/python/designer/install_script
You won't need the designer part of the script.
Edit: If you update then you won't need to set the default pyhton version, I have pushed a change to the install script so it is python3 only.
Last edit: 5 years 2 months ago by phillc54.
Time to create page: 0.258 seconds
