QtplasmaC- actualization error
4 years 5 months ago #243400 by Marçal
Replied by Marçal on topic QtplasmaC
I think so.
The red LED from 7i77 circuitboard is turned on which means according to the manual that there is a field I/O fault. However, when I use the 3 axis configuration, without the THCADs it turns green and works well. In both THCAD the CR2 led blinks and the CR5 led glows steadily. Nevertheless, the CR5 led is not green but yellow.
Do you think it is a coding problem, a wiring one, or can be both?
4 years 5 months ago - 4 years 5 months ago #243800 by Marçal
I am still stuck with this. Since I cannot make the program work with Plasmac, I would like to update to LinuxCNC 2.9 to use QtPlasmaC. As I mentioned, I have Debian 9 stretch. I believe that the master branch is only available with Buster, so I'll try to install MX Linux following snowgoer steps.
Last edit: 4 years 5 months ago by Marçal. Reason: I do not have that question anymore
4 years 4 months ago #244517 by Marçal
Just to give you feedback. I managed to install linux 2.9 with QtPlasmaC following snow guide. Thank you for that!
First I downloaded the last version of MX and it does not work with it. It has to be 19.4 like it is said on the slides.
4 years 4 months ago #244518 by snowgoer540
Replied by snowgoer540 on topic QtplasmaC
Glad to hear you got it going!
4 years 3 weeks ago #253898 by edgemir
I have a configuration that worked correctly before (the last one where it works is 7460), but after an update it no longer works for me. To test I have used the sample configurations and they work well, but the problem is if I change the configuration mode to type 2, it sends me VCPWINDOW errors, I have tried creating a new configuration from STEPCONF and in the same way in mode 0 and 1 they work normally, but if I change it to mode 2, it marks the errors that I have made previously, I attach the error report files, greetings and thank you very much for your support...
4 years 3 weeks ago #253917 by snowgoer540
Thank you for the report. I just pushed a fix, it should be good to go as soon as the buildbot is done doing its thing.
The following user(s) said Thank You: edgemir
Time to create page: 0.180 seconds
