- Thank you received: 49
If the THC is disabled or if THC is enabled and not activated then the IHS skip will occur if the start of the cut is less than Skip IHS distance from the last successful probe.
So long as you have a large enough Skip IHS distance it will work.
This logic makes sense to me. It doesn't currently work this way though, does it? Like you said earlier, if THC is enabled but not active at the end of the cut, IHS skip will not function. It should (in theory) default back to the last successful probe in this case.
Yeah, it is bad enough on a PC, I rarely reply on a mobile and if I do it is usually without quotes.Edit: Wow, editing on mobile is a disaster
