Homing Issue "home switch inactive before backoff"
4 years 4 months ago - 4 years 4 months ago #245245 by little_sparky
Hi All,
I have been running PlasmaC for about 2 years now and my X-axis limit switch just randomly started playing up. When I home all axis, the Z homes fine but the X either goes slightly past/before the proximity limit switch and stops, where a "Home Switch Inactive before start of backoff move j=0" error message comes up, or it keeps going past the sensor and crashes into the hard stop. The light on the limit switch still comes on as if it is working. I can open and close PlasmaC about 2-10 times and keep re-homing and eventually it will work.
Does anyone have any ideas? Is it odd that this has randomly started after 2 years of it working fine?
As always, your help and knowledge is very much appreciated.
Thanks, Little_sparky
edit: I am using 12v proximity limit switches, no pull up resistor and no shileded cable. This is what I will be looking into, but wondered if there might be another way to identify/fix the problem.
Last edit: 4 years 4 months ago by little_sparky.
4 years 4 months ago #245248 by Clive S
It could be that the sensor appears to be working ( ie it lights up when triggered) but the wire going to it could be broken intermittent.
So check the wiring where it might be flexing.
4 years 4 months ago #245262 by tommylight
First, try lowering "home_search_velocity" to at least half of what you have now.
4 years 4 months ago - 4 years 4 months ago #245509 by little_sparky
Update:
So I did the above and I think it was a dodgy switch. I have purchased a new inductive proximity sensor, but this time I have a normally closed sensor instead of normally open. I have wired it up and I now need to invert the signal.
I tried to put -not at the end of the
# - - - HOME - X - - - #
net home-x    <= hm2_7i76e.0.7i76.0.0.input-13-not
in the .Hal file however I now get an error when trying to open PlasmaC. Is there somewhere else I need to put -not?
what is the best way to edit the base configuration? I tried to use pncconf but I had no luck.
thanks
little_sparky
4 years 4 months ago - 4 years 4 months ago #245510 by little_sparky
Also, I have wired the NC sensor exactly the same as the NO sensor, is this correct? Do I just need to invert the signal.
it is a PNP NC Inductive Proximity Limit Switxh
4 years 4 months ago #245622 by andypugh
Appending -not is the usual way.
Though the docs:
linuxcnc.org/docs/stable/html/man/man9/h...eral%20Purpose%20I/O
Mention both in-not and in_not. That needs fixing.
I don't have a 7i76 but on my 5i25 the postfix is actually _not, so maybe try that?
5 bit OUT TRUE hm2_5i25.0.gpio.000.in 5 bit OUT FALSE hm2_5i25.0.gpio.000.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.001.in 5 bit OUT FALSE hm2_5i25.0.gpio.001.in_not 5 bit OUT TRUE hm2_5i25.0.gpio.002.in 5 bit OUT FALSE hm2_5i25.0.gpio.002.in_not
Though the smart-serial driver (ie, 7i76 field IO) uses -not:
github.com/LinuxCNC/linuxcnc/blob/master...mot2/sserial.c#L1183
And it _should_ be -not according to the specifications...
linuxcnc.org/docs/2.6/html/hal/canonical-devices.html
But probably too late to make it consistent now.
Time to create page: 0.076 seconds
