qtplasmac lost arc = turn off and on again?
3 years 10 months ago #259460 by Mud
Hi all, I may be missing something, but if I lose the arc ok on piercing I can't seem to get another arc until I quit out of qtplasmac and come back in. This is true for resuming the program, or starting a new cycle. Even turning on 'ignore ok' doesn't get the arc back until closing and reopening qtplasmac. Same for toggling the torch enable, dismissing errors, etc. Any ideas?
3 years 10 months ago - 3 years 10 months ago #259468 by caretech
Have you tried waiting a full minute, to see if arc occurs after a full 60 second wait? This is the behavior I had. It's unnerving, waiting for a full minute of complete silence, then a sudden arc blast again! Made me jump every time.
Fortunately, there is an easy fix for this (if your problem is the same as mine). Set the Retry Delay to a more reasonable number. I have no idea why mine was set to 60 by default. I changed to 2 or 3, forget which, and now retries happen much more quickly after a failed pierce.
The Retry Delay setting is found in the Parameters tab.
Last edit: 3 years 10 months ago by caretech.
The following user(s) said Thank You: Mud, snowgoer540
3 years 10 months ago #259469 by Mud
Retry delay was indeed 60 - I bet you're right!
3 years 10 months ago - 3 years 10 months ago #259510 by snowgoer540
I see what's causing the issue in the code.  We will push a fix after a bit. Fix pushed.
For anyone who runs into this, just change the retry delay in the arc section of the parameters tab.
Thanks for the inadvertent bug report :)
Last edit: 3 years 10 months ago by snowgoer540.
The following user(s) said Thank You: tommylight, Clive S, Mud, caretech
3 years 10 months ago - 3 years 10 months ago #259601 by caretech
snowgoer540 post=259510 userid=26427
Ha, well I thought of reporting this before but figured maybe I was the only one running into it.
I noticed yesterday that the official docs show a Retry Delay of 60 in the screenshot, here: www.linuxcnc.org/docs/devel/html/plasma/...ml#qt_parameters-tab
Thanks for the fix!
3 years 10 months ago #259617 by Mud
Was the original intent for this function to address duty cycle limits? Would explain making it long.
Time to create page: 0.420 seconds
