qtplasmac lost arc = turn off and on again?
14 Dec 2022 13:18 #259460 by Mud
Hi all, I may be missing something, but if I lose the arc ok on piercing I can't seem to get another arc until I quit out of qtplasmac and come back in. This is true for resuming the program, or starting a new cycle. Even turning on 'ignore ok' doesn't get the arc back until closing and reopening qtplasmac. Same for toggling the torch enable, dismissing errors, etc. Any ideas?
14 Dec 2022 15:22 - 14 Dec 2022 15:25 #259468 by caretech
Replied by caretech on topic qtplasmac lost arc = turn off and on again?
Have you tried waiting a full minute, to see if arc occurs after a full 60 second wait? This is the behavior I had. It's unnerving, waiting for a full minute of complete silence, then a sudden arc blast again! Made me jump every time.
Fortunately, there is an easy fix for this (if your problem is the same as mine). Set the Retry Delay to a more reasonable number. I have no idea why mine was set to 60 by default. I changed to 2 or 3, forget which, and now retries happen much more quickly after a failed pierce.
The Retry Delay setting is found in the Parameters tab.
Last edit: 14 Dec 2022 15:25 by caretech.
The following user(s) said Thank You: Mud, snowgoer540
14 Dec 2022 15:27 #259469 by Mud
Retry delay was indeed 60 - I bet you're right!
14 Dec 2022 22:21 - 14 Dec 2022 22:54 #259510 by snowgoer540
Replied by snowgoer540 on topic qtplasmac lost arc = turn off and on again?
I see what's causing the issue in the code.  We will push a fix after a bit. Fix pushed.
For anyone who runs into this, just change the retry delay in the arc section of the parameters tab.
Thanks for the inadvertent bug report :)
Last edit: 14 Dec 2022 22:54 by snowgoer540.
The following user(s) said Thank You: tommylight, Clive S, Mud, caretech
16 Dec 2022 01:57 - 16 Dec 2022 01:59 #259601 by caretech
snowgoer540 post=259510 userid=26427
Ha, well I thought of reporting this before but figured maybe I was the only one running into it.
I noticed yesterday that the official docs show a Retry Delay of 60 in the screenshot, here: www.linuxcnc.org/docs/devel/html/plasma/...ml#qt_parameters-tab
Thanks for the fix!
Last edit: 16 Dec 2022 01:59 by caretech.
16 Dec 2022 08:45 #259617 by Mud
Was the original intent for this function to address duty cycle limits? Would explain making it long.
16 Dec 2022 13:28 #259634 by snowgoer540
Good catch, I updated that as well.
The following user(s) said Thank You: caretech
16 Dec 2022 13:34 - 16 Dec 2022 13:35 #259635 by snowgoer540
I believe the intent for having an adjustable retry delay had to do with the fact that some power sources wont retry immediately (if a delay of a certain length hasn't elapsed). Hypertherm for example, requires no delay to attempt to restart the arc. Others do.
The code in the handler defaulted this parameter to 0 if it was not present in the preferences file (which it never is upon the very first run of the GUI). The issue was that the minimum value for the spinbox you see in the GUI was 1. When that happens, qtvcp apparently defaults to the maximum value, rather than the minimum value. The maximum value for the spinbox was set at 60.
Last edit: 16 Dec 2022 13:35 by snowgoer540.
The following user(s) said Thank You: Mud, caretech
Time to create page: 0.270 seconds
