Error with T0 M6 (select plasma tool)
3 years 9 months ago #263466 by edgemir
Yesterday I made a new installation of linuxcnc with qtplasmac, when I try to run a code generated with sheetcam the torch stays immobile and remains at that point without sending any type of error, simply no axis moves. Trying to solve the problem, I generated a code from conversational mode and this code does execute without problems. What I found is that if I remove the line in the header in the initialization section of the material, the code T0 M6 the code runs again without problems. I don't know if there is any change that I should make to solve this problem, greetings and thanks for the support...
3 years 9 months ago #263469 by snowgoer540
Can you upload the gcode file you are having issue with?
Otherwise we are just guessing :)
The following user(s) said Thank You: edgemir
3 years 8 months ago #263487 by edgemir
Of course, I attach both codes, the problem I found is in the header, regards
3 years 8 months ago #263489 by snowgoer540
Both work.ngc and no-work.ngc run fine on my Virtual Machine over here.
I tested both on both a metric machine, and an imperial one.
Can you post a backup of your config (made from the settings tab)?
3 years 8 months ago #263545 by edgemir
Thanks a lot for your time, I notticed that I delete the section for tool-number in the hal file,
net tool-number <= iocontrol.0.tool-prep-number net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
restored this lines and there no problems any more...
3 years 8 months ago - 3 years 8 months ago #263552 by snowgoer540
Looks like you are working with a fairly old configuration.  Did you migrate from plasmac?
Of the three lines you posted above, you only need to comment out/delete this one:
The other two should stay.
You could post your config if you'd like us to double check it.
Last edit: 3 years 8 months ago by snowgoer540.
Time to create page: 0.070 seconds
