Error with T0 M6 (select plasma tool)
01 Feb 2023 21:33 #263466 by edgemir
Error with T0 M6 (select plasma tool) was created by edgemir
Yesterday I made a new installation of linuxcnc with qtplasmac, when I try to run a code generated with sheetcam the torch stays immobile and remains at that point without sending any type of error, simply no axis moves. Trying to solve the problem, I generated a code from conversational mode and this code does execute without problems. What I found is that if I remove the line in the header in the initialization section of the material, the code T0 M6 the code runs again without problems. I don't know if there is any change that I should make to solve this problem, greetings and thanks for the support...
01 Feb 2023 21:55 #263469 by snowgoer540
Replied by snowgoer540 on topic Error with T0 M6 (select plasma tool)
Can you upload the gcode file you are having issue with?
Otherwise we are just guessing :)
The following user(s) said Thank You: edgemir
02 Feb 2023 02:35 #263487 by edgemir
Replied by edgemir on topic Error with T0 M6 (select plasma tool)
Of course, I attach both codes, the problem I found is in the header, regards
02 Feb 2023 03:07 #263489 by snowgoer540
Both work.ngc and no-work.ngc run fine on my Virtual Machine over here.
I tested both on both a metric machine, and an imperial one.
Can you post a backup of your config (made from the settings tab)?
02 Feb 2023 20:07 #263545 by edgemir
Thanks a lot for your time, I notticed that I delete the section for tool-number in the hal file,
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
restored this lines and there no problems any more...
02 Feb 2023 23:01 - 02 Feb 2023 23:02 #263552 by snowgoer540
Looks like you are working with a fairly old configuration.  Did you migrate from plasmac?
Of the three lines you posted above, you only need to comment out/delete this one:
The other two should stay.
You could post your config if you'd like us to double check it.
Last edit: 02 Feb 2023 23:02 by snowgoer540.
03 Feb 2023 16:24 #263605 by edgemir
It's not too old, I did it with stepconf last week, right now i only have the ini and the hal file
03 Feb 2023 16:30 #263606 by snowgoer540
I thought you said you were running qtplasmac?
That ini file says very differently.
03 Feb 2023 17:36 #263613 by edgemir
opps you're rigth, these are the files...last one was the config to check the set up for motors and drivers...
Time to create page: 0.106 seconds
